Question about Kenmore Elite HE4 Electric Dryer
What does code "SUD" mean? - Kenmore Elite HE4 Electric Dryer
  • 864 Answers
Machine has sensed a high level of suds from using too much detergent.
Posted on Oct 06, 2009
Testimonial: "Thank you so much!!!!"
Washer stops running and displays code SUD. The water doesn't drain until It's put on the rinse/spin cycle.
Make sure you are using HE (High Efficiency)detergent. The codes could mean your washer is telling you it has used a built in "SUD" routine during final rinse
Jul 18, 2015 | Whirlpool Duet GHW9150P Front Load Washer
MHW6000XW LIST OF ERROR CODES AND WHAT THEY MEAN
F20 water only problem insufficient water supply open both hot and cold unclog hoses
F21 Drain problem clogged,frozen kinked
SUD excess sud using non he detergent or to much detergent
F22 front door lock door not closed properly
For these select poepwer/cancel twice to cancel cycle
Other f codes select power/cancel twice select drain& spin if youhave excess water
Jul 10, 2015 | Maytag MHW6000XW - MaximaTM...
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting a sud erroro code
This usually means that you have used an excess of detergent. Front loaders use less detergent as well as less water. Try running the machine without detergent to remove the over supply of detergent in the machine. You may have to physically remove the excess by hand at first. Hope this helps!
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code "SUD"
SUD error means there is to much soap being added, the washer will shut down, if it cents to much soap
Jan 12, 2010 | Kenmore Elite 45986 Front Load Washer
Sud code comes up and stops and just beeps
Are you using HE detergent (for all front load washers ) or regular detergent ? SUD means suds lock from regular detergent .
Jul 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer flashes P 2 and now SUD will not finish cycle
F-2 IS ERROR CODE SUD MEANS NOT USING H E DETERGENT,, REMOVE DEBRIS FROM PUMP AND SHOULD RESOLVES YOUR PROBLEM ,, REMOVE BOTTOM PANEL 3 SCREWS ONCE REMOVE PUMP FILTER RIGHT IN FRONT BE SURE TO HAVE ALOT OF TOWLES READY MACHINE STILL STORES 3 GALLONS OF WATER
Nov 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
