Question about Safe International Stack-On 19-Gun Convertible Safe with Combination Lock - 26 13/16in.W x 17
Forgot my cobination to my stack on elite but dont have money for a locksmith
I forgot combination to my sentry safe model #POO5C and have been trying forever to open this up. Can you help me? No, I don't know the serial number either. Ugh.
The manufacturer will help you if you have the serial number, pay money and send them a sworn affidavit that the safe is yours. It has to be one of those electronic safes.
The alternative is that you call a locksmith and they drill the door.
Jan 03, 2016 | Home Security
Where can i get the factory set combo on my stack on safe
You will have to contact the manufacturer and have proof the safe is yours. No one is going to help you not even a locksmith till you can prove it is yours.
Nov 25, 2015 | Stack-On Stack On 16 Gun Safe with...
I need the key code for my 2009 hhr keys are lost and i dont have enough money for a locksmith p[ease help
Your going to need to go to the dealer ! That's the only place you can get the key you need !
Sep 23, 2015 | 2009 Chevrolet HHR
I have a Stack On Elite gun safe and trying to reset passcode. I've pushed in the red button and they yellow botton on key pad is one. The rest of the keypad doesn't work which means I...
http://s3.amazonaws.com/stack-on-production/downloads/62/Elite_Manual_-_Electronic_Lock.pdf?AWSAccessKeyId=08CNY13ZYZNXTVEEJX82&Expires=1413690335&Signature=1JTuTtTym%2F06NzYkH9fS4kIbi6M%3D
Oct 09, 2014 | Stack-On GSX-836-DS - Elite 36 Gun Fire...
Want to know if I can stack a kenmore elit gas dryer on a kenmore elite washer and on top of a 10 inch pedistal or will it be too tall?
The appliances were not designed to be stacked so I would not attempt it if anything I would build a shelf (ledge) to put the dryer on, then bracket it to the wall but be careful of the height especially with a gas dryer and be sure to have plenty of space for airflow. Good luck
Mar 27, 2014 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a sentrey key pad safe and forgot combination dont feel like paying to have a locksmith come open it any suggestions
There should be a factory code, printed on the instruction manual. Otherwise, the factory might be able to help, for a nominal charge. The reason a locksmith charges for this service is they know (at least they should know) how to do it without damaging the safe. If you can take it to the locksmith, you'd avoid the trip charge. Obviously, I can't post a detailed solution here.
Aug 03, 2011 | Safe International Digital Electronic Safe...
I forgot my combination i tried putting a couple different numbers in after three trys the key pad locked and now when i type any numbers in it doesnt work. how do i unlock my safe?
after 3 trys the keypad does go into lockout mode but it should only last for about 15 minutes and then let you retry 3 more codes to try and open. if you still do not know what the combo is you can usually call the maker of the safe and with the serial number you might be able to get the original combo that the safe was set to when it was purchased ( this is a factory set combo ) --- now if that does not work, your next step will be to call a safe tech ( locksmith ) to set up a auto dialer,, this takes about a full 24 hours to get the combo right. the safe tech can also drill a small hole behind the dial and manually remove the locking bolt. after the safe is opened the locksmith will fill the hole and reset the combo for you ( also replace the battery at this time too ).
c...
Jan 15, 2011 | Stack-On Stack On 16 Gun Safe with...
Digital Electronic Security Safe S2120.
You will probably have to call a locksmith who specializes in digital safes, or you can contact hardline and give them the serial no. of the save and proof of purchase to get the code or key. You will probably need proof of purchase for the locksmith to.
Sep 18, 2009 | Kitchen Appliances - Others
I lost the cobination for the safe and i cant open it
To retrieve your lost sentry fireproof safe combination. First, find your safe's Model and Serial Number. The Serial Number is printed on the small label on the right side of safe (on paper tag near hinge) or under handle. As this information is confidential a valid credit card and email is needed to verify a customers name and address
sentry safe combination archives searches. Do come with a service charge although it's definitely cheaper then buying
a new home electronic sentry fireproof safe.
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements.
Apr 01, 2008 | Sentry Fireproof Safe
Safe International Stack-On 19-Gun Convertible Safe with Combination Lock - 26 13/16in.W x 17 Logo
1,512 people viewed this question
Top Safe International Home Security Experts
Computer Repairing
Computer Repairing
Theo Nikolaidis
Theo Nikolaidis
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
