Question about Canon ImageRUNNER 1670F Copier
How do you progam the 1 touch key? also delete a
How do you progam the 1 touch key for numbers that you dial all the time? also delete a number you no longer use
  • 318 Answers
Press the additional key button,scroll to no 3 faxsettings,press ok,scroll to no 5 pro touch key,press ok,Program the one touch keys from 1 to 12
Posted on Dec 06, 2009
Needs to reprogram fax machine, has old fax numbers in
1. Press Menu/Set, 2, 3, 1.
2. Press the One Touch key where you want to store a number.
The LCD shows the location you selected.
3. Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter a pause in the dialing sequence (for example, to wait for an "outside line"), press Redial/Pause as you're entering digits. A dash appears on the LCD. Pressing Redial/Pause enters a 3.5 second pause when the number is dialed.
4. Use the dial pad to then enter the name (up to 15 characters), and then press Menu/Set. You can use the chart on page 4-2 to help you enter letters-OR-To store the number without a name, press Menu/Set.
5. Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
When you dial an auto dial number, the LCD shows the name you've stored, or, if you haven't stored a name, the number you've stored.
If you loose electrical power, auto dial numbers in memory will not be lost.
(For USA Only) One-Touch key 1 has been pre-programmed for the Brother faxback system. One-Touch key 2 has been pre-programmed for the CallManage long distance plan. You can override them if you wish.
Note If you need to store a pause longer than 3.5 seconds, press Redial/Pause two or more times.
Note - You can store Groups (for Broadcasting) on the One Touch keys.
Dec 11, 2010 | Brother IntelliFax-2820 Laser Fax
How do I delete speed dial numbers on the Intellifax 2820?
Changing One Touch (For FAX Models Only) and Speed Dial Numbers
If you try to store a One Touch (FAX models only) or Speed Dial number in a
location where a number is already stored, the LCD shows the current name stored there, and then prompts you to either:
1 Press 1 to change the stored number-OR- press 2 to exit without making a change.
2 Enter a new number, and then press Menu/Set.
• If you want to erase the whole number, press Stop/Exit when the cursor
is to the left of the digits. The letters above and to the right of the cursor will be deleted.
• If you want to change a digit, use or to position the cursor under the digit you want to change, and then type over it.
3 Follow the directions beginning at Step 4 in Storing One Touch Numbers
(For FAX Models Only) and Storing Speed Dial Numbers.
Dec 03, 2010 | Brother IntelliFax-2820 Laser Fax
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
IntelliFax-4100e
go into menu, arrow over until you see 2. Fax hit set, then arrow until you see 1. one-touch speed dial, then hit set. touch the one-touch button you want to change, then the number 1 to change it, it will display the number, hit clear to delete it then dial the new number hit set and you're done.
Feb 11, 2010 | Brother IntelliFax-4100e Fax
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
How do you set and delete speed dials on minolta 2800 fax
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Nov 28, 2009 | Minolta MF1600E Plain Paper Laser Fax
Program numbers
Storing a Number in Memory
1. Press the STORE button. ENTER TEL. NO. is displayed.
2. Use the keypad to enter the phone number. You can put spaces in the number and it will still dial correctly. To enter a space, press NEXT button.
• To scroll forward or backward, use NEXT (when the cursor is not at the end of the number) or REVIEW.
• To erase the current digit, press DELETE.
3. When finished, press STORE. ENTER NAME is displayed.
4. Use the keypad to store a name (up to 16 characters). More than one letter or character is available in each of the number keys. For example, to enter the letter "A," press the 2 key once. For a "B," press the same key twice. For a "C," press it three times.
• To add a space, press NEXT.
• To scroll forward or backward, use NEXT or REVIEW.
• To erase the current character, press DELETE.
5. When finished, press STORE. MEMORY LOCATION is displayed.
6. Press the memory location number (0-9 or A, B, C) to store the number.
Here is a link for this telephone off the GE website:
http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
May 11, 2009 | GE 29897GE1 Corded Phone
Group code
I believe what you want is at the bottom of this list.
If you frequently send faxes to the same group of telephone numbers, you can assign these numbers to a group.
Only Speed Dial and One Touch numbers can be assigned to a group. A maximum of 25 Group Numbers (WorkCentre Pro555) / 50 Group Numbers (WorkCentre Pro575) can be assigned (in the range 1-1999). Preset group numbers can also be used for polling.
The following information is included below:
  • Create a new group
  • Add numbers to an existing group
  • Delete numbers from an existing group
  • Delete an existing group
To print the Group Phonebook, see the Related Items below for additional information.
Create a new Group:
  1. From the Standby Mode, press the [Menu] (up arrow) button on the Control Panel, then press [3], [3].
  2. Use the numeric keypad to enter the Group Dial number (1-1999) you want to assign to this group.
  3. Press the [Enter] button. The screen will display a name.
  4. Use the numeric keypad to enter the Group Name (20 characters maximum), then press [Enter].
  5. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, then press [Enter].
    NOTE: The One Touch and Speed Dial numbers must already be programmed. See the Related Items below.
  6. Repeat step 5 to enter additional numbers.
  7. When you have entered each number you want to include in this group, press [Enter].
    NOTE: Group Transmissions are easier if a group is linked to a One Touch button.
  8. To assign this group to a One Touch button, press the One Touch button. To skip this step, press [Enter].
  9. Press the [Exit] or [Stop] button to return to the Standby Mode.
To add numbers to an existing Group:
  4. Press [2] to modify this group.
  5. Use the numeric keypad to enter a new group name, then press [Enter], or press [Enter] to retain the old name.
  6. Press the One Touch button you want to include in this Group, or enter the Speed Dial number, and then press [Enter].
  7. Repeat step 6 to enter additional numbers.
  8. When you have entered each number you want to include in this group, press [Enter].
  9. Press the [Enter] button.
  10. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete numbers from an existing Group:
  6. Press the One Touch button you want to delete from this Group, or enter the Speed Dial number, and then press [Enter].
  7. Press [1] to delete this number.
  8. Press [Enter] to delete the number, or press the [Exit] or [Stop] button to exit without deleting number.
  9. Repeat steps 5 through 7 to delete additional numbers.
  10. When you have deleted each number from this group, press [Enter].
  11. Press [Enter].
  12. Press the [Exit] or [Stop] button to return to the Standby Mode.
To delete an existing Group:
  2. Use the numeric keypad to enter the number of the Group you want to delete, then press the [Enter] button.
  3. Press [1] to delete the group number.
  4. Press the [Exit] or [Stop] button to return to the Standby Mode.
elem_1_spacer.gif Related Items:> See AlsoHow To Print and Read the Group Phonebook Report
> See AlsoHow To Modify the Default Resolution and Contrast Settings
> See AlsoHow To Assign / Modify Speed Dials in the Phonebook
Dec 11, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Brother faxes 8360P and 8000P - how do I progamme the machine to dial a 9 before each number please ? as my machines are connected to extensions on the PABX. Thanks
As I'm aware you can not program a number before every number you use. However you can progam the one touch or speed dials you can enter the 9 before the numbers. On some systems thay may need 9 then a pause then the number.
Nov 14, 2008 | Brother Office Equipment & Supplies
Fax not being sent
Somehow, a group dial # has been set. Here is how to delete it:
NOTE: Group Dial Numbers are entered using the One-Touch keypad on the left hand side of the WorkCentre. To change a Speed Dial that is within a Group Dial, the Group must be deleted first.
  1. Press the [Menu] button.
  2. On the left hand side of the Control Panel press the One-Touch [12] button.
  3. The LCD Display will read 'Select One-Touch for Group [01-20]'.
  4. Press the One-Touch key to be used for the Group Dial.
  5. One of two displays will appear:
    • If the Group Dial number has not been used:
      1. The LCD Display will read 'Group No: ### 1. YES 2. NO'.
      2. Using the Dialing Keypad press [1] to accept or
      3. Press [2] to return to step four.
      4. The LCD Display will read 'Enter One-Touch / Speed Dial> ##'.
      5. Continue with step 6.
    • If the Group Dial number has been used:
      1. The LCD Display will read 'Group ## Used 1: Renew 2: Other'.
      2. Using the Dialing Keypad press [1] to 'Renew'. This will cancel the Speed Dial or Group Dial entry and the Group Dial will be deleted.
      3. Press [2] to keep the current entry and select another Group Dial
      4. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
        Thanks, Joe
Apr 26, 2008 | Xerox WorkCentre 470CX InkJet Printer
Canon ImageRUNNER 1670F Copier Logo
51 people viewed this question
old marine
old marine
