Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Light stays on
I smelled smoke in the Kenmore Trio, and found the food on the top shelf warm. The lighting unt was melted and it turned out the light was staying on when the door closed. Sears replaced the light unit and both switches, but the problem continues. He said there is nothing more to fix. What is going on here???
Susan
srw406@yahoo.com
  • Srw406 Dec 23, 2007
    Replace what unit?? The light unit and both switches have been replaced. The fridge is out of warranty is cooling fine. Do I need another light unit?? Is this an ongoing problem with this model, which is made by LG. I was expecting more info for the $9.99 I paid for this advice.
  • 790 Answers
Posted on Dec 23, 2007
    Master:
    Sergeant:
  • 482 Answers
I would replace the unit. This could start a fire.
  • farren wadley
    farren wadley Dec 23, 2007
    I would replace the light unit.
GE side by side refrigerator main light bulb stays on even when door is shut firmly.
There is a switch just inside the door in most on the roof of the fridge, make sure it is not damaged.
Jul 02, 2017 | Refrigerators
LIGHTS STAY ON IN FRIDGE
LG had a problem with the control board going bad allowing the interior lights to stay on even when doors are closed. you need to get in touch with LG concerning repair MY UNDERSTANDING is there is a safety recall and it will be repaired for free. in the mean time unsrew the light bulbs so they dont melt down your liner...
Oct 03, 2012 | LG Refrigerators
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Top refrigeration portion smells like something is burning, warm temperature on top portion, bottom freezer appears to be working, unplugging and switching circuit breaker does not resolve problem, smell...
I need to let you know that your refrigerator may fall under a consumer alert. It is possible that the lights are remaining on while the doors are shut and can result in property damage. The issue is the light melt the plastic and damage the refrigerator, food and possibly smoke damage. If this is not the case please let me know and I will assist you if there is something other that this causing the problem. Thanks Sea Breeze
Oct 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Light bulb stays on in Kenmore Elite fridge Model # 795.77559600
I had the same problem with a kenmore elite fridge and recieved the same response from Sears customer service!!! File a complaint with your local BBB. Sears contacted me within the day and sending out a tech at their expense only after the complaint was filed. Good luck. Elana
Jul 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite Trio Frige...Beeping three times in a row suddenly
this unit has a history of the light circuit failing and it will cause the lights to either stay on or off. if they stay on, it will melt the housing around the upper bulb area. it has a recall and should be covered by sears for no charge. it is the control board failure and has a sticking relay for the light circuit, needs board replaced.
the 3 beeps are the unit thinking it has a door open. turn off the alarm on the door control board and call sears 800 # for repair.
Dec 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 30, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
795.77573600
I just saved my fridge / home too, smelled what I thought to be an electrical fire when I opened the Trio doors, immediately looked at the bulbs as a probable cause, and sure enough, the base of the bulb sockets were burned-brown and the plastic housing was to hot to touch without a hot-mit.
Unscrewed the bulbs and set aside out of children's reach and combustable materials.
I'm filing a complaint and service repair today. 8/3/08
Sean-Jon
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
184 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
