Question about Dryers
How do you test the voltage for a dryer? Bought a testing meter to test the continuity of (250 or 120...) just don't know how to go about it.
  • Dryers Master
  • 8,220 Answers
You cannot test continuity with this unless you have a death wish. You could see if you had power going to an object but that would not let ye know if power was going through it. Both sides of the heating element could be hot and therefore light up the tester but that would not PROVE the heater was ok. To do that you would need to remove a wire (while live) connect up to the live 240 volt wire and the leg to the heater THEN if the light comes on yeah you have continuity but you could be KILLed in the process. It would be better to get a meter and check each item for continuity:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 06, 2009
  • Dan Webster
    Dan Webster Oct 06, 2009
    Set the meter to OHMS and touch the leads together. Notice the needle move? That is showing a complete circuit.Rmove a wire from each item so ye won't get a false reading.
How do I know if I have continuity on my Sperry dsa 500
Set the knob to the ~600V position. With the power on/connected, place one test lead on one side of the fuse and the other test lead on the other side of the fuse. Be careful not to touch anything with your hand or you will get shocked. If you read voltage the fuse is bad. If you don't read voltage the fuse is bad.
Alternately you could DIS-connect power remove the fuse and test the fuse for OHMs, which on your meter is the last icon with the ((((.
It will beep and/or read very low ohms <5.
Here's the manual -
Sperry Instruments DSA 500 Operating Instructions
Jan 02, 2018 | Whirlpool Dryers
My bosh dryer won't heat I reset the red button many times and I don't know what to do
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Mar 26, 2015 | Dryers
Ned5240tqo
I don't know what tools and skills you have, but driers are generally fairly basic. You will need a multi meter for checking voltages. First ensure the power sw operates properly by checking power both sides of the switch with power off/unplugged, with the meter on Ohms, that's the omega symbol. It tests continuity. You are looking for contiuity through the machine. I found a power sw recently felt ok but internally no good. Does the drier have an electronic controller or rotary timer/heat set??
Apr 18, 2012 | Amana Dryers
My Dell insperion won't power up at all. I bought a new battery and tested the charger and am getting the 19.5V that I am supposed to get. I don't know how to test the battery to see if it is...
If working should turn on with adapter plugged in, maybe the internal jack is broken, move adapter plug around slightly and see if it moves at all, should not. Does any lights com on or do you hear the fan ?
Nov 01, 2017 | Dell Inspiron 1150 Notebook
How do i test my dryer fan motor
Connect it to a power source after unplugging the connector? Is the fan freely rotating and have you checked the windings for continuity with a test meter? If it passes those tests its probably ok unless it has shorted turns on the windings, which is why the final test should be to connect it independently and see if it runs. A better way of doing things would be to monitor the voltage across the motor connectors with a test meter when it is supposed to be running. If it has volts but does not run then it is faulty. BE CAREFUL AS IT IS HIGH VOLTAGE SO MAKE SURE YOU DON'T TOUCH ANY LIVE PARTS AND ANY CONNECTIONS ARE INSULATED
Jan 28, 2011 | Hotpoint Aquarius WD63 Front Load...
Kenmore electric dryer model number 86860100 dryer not heating.....cleaned out vents not the problem....everything else seems to work.. I had seen in the past it glow in back of the dryer so I turned out...
hello there:
Testing with an ohm meter checking on a dryer....
These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element 8-12 OHMS
Jan 09, 2010 | Kenmore Dryers
The dryer is not heating
Hello there here is a list of things to check
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only. To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
Jan 09, 2010 | Dryers
Dryer works but no heat, have a multimeter but need to know how to use and what to test
no heat at all? open front to access heater box, set meter to ohms. (unplug dryer), test for continuity across element connections. (disco at least one wire at each part to ensure accurate results for each check. then reconnect when done) some ohms is good here. if OL on meter then its open/bad. check each thermostat on side. they should all be 0 ohms. post results.
At terminal block in rear check voltage while plugged in. set meter to volts AC. each outside terminal to center should show 120 V approx. then together 240v. if 120 only on one side or one side significantly less than 120 then check outlet. Missing one phase/leg of supply can cause motor to run but no heat.
May 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Heating element continuity?
Unplug the dryer from the wall. There are 2 wires connecting power at the heating element. Take one of these wires off, doesn't matter which one, but take at least one of the 2 off. Then put your meter probes across the terminal of the heating element where you took the 1 wire off and the other terminal of the heating element that still has a wire on it. Your meter will pretty much read full continuity if good, no reading at all if bad. Also check from one of these terminals of the element with one meter probe going to the metal frame of the unit. You should get no reading. If you do the element is shorted and would have likely tripped your house breaker.
Better to test a heating element for voltage with your meter like I described to you in your other question. I've seen heating elements read good when just doing a continuity test, however once voltage is applied and they start to heat they can expand and open up, thus not work, even though testing good when doing just a continuity test. Not always, but sometimes, it does happen enough to note to you.
Mar 11, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
