Question about Canon P23-DHV Calculator
I do not know how to feed the paper into this. I
I do not know how to feed the paper into this. I took it to Staples store, and the young man was pretty rude. Said he needed a manual to do it. I think I could do it with a manual. I do not have one. Thanks Jo
  • 51 Answers
It feeds into the slot just below the back top edge (see the manual. Be sure thatyou have the proper size papre--2 1/4 inch.
CLICK HERE:
http://downloads.canon.com/cpr/software/calculator/P23-DHV-(USA-HWB).pdf
ps. let the manual load all the way, it's pretty big.
Good luck
Posted on Oct 07, 2009
How to install paper
Without a manual, look at the picture of the calculator. Mount the paper, with the feed coming forward and over the top of the calculator. Insert the paper (recommend cutting it flush) into the feed slot in the back. Then use the paper advance key to advance the paper through the rollers. Unfortunately the manual is not available from the Staples website. Good Luck,
Mar 02, 2015 | Staples SPL-P100 Printing Calculator
Does error P07 on a Canon DR-G1100 indicate that there is a paper jam or that a counter needs to be reset?
P007 indicates that a document has jammed before exiting the registration post sensor. Make sure the path is clear and no staples are stuck in the rollers. I like to use a microfiber cloth, with a small amount of 50/50 alcohol on it, to wipe down the entire feed path; top and bottom. The microfiber cloth will grab staples that may be wedged between the rollers/roller openings. Beyond that, it could be a timing issue from a bad/loose drive belt. Actually, there are quite a few things that could cause a paper jam before exiting the post registration sensor. Wipe it down and let me know.
Scan-R-Store
Dec 01, 2014 | Canon DR Office Equipment & Supplies
Can not feed paper
First try moving the switch manually to reverse. The machine should start. This may cause some paper to appear in the slot where you place the paper to be shredded. If it doesn't start, your problem may be more serious or complex and you should get in touch with the Staples store where you purchased it.
It may be that the paper you are trying to use is too lightweight. Try inserting a piece of cardboard (SLOWLY SO AS NOT TO LET THE BLADES CATCH THE CARDBOARD - LETTING IT CATCH THE CARDBOARD MAY BE BEYOND THE UNIT'S CAPACITY). If this starts the shredder, quickly remove the cardboard. If it continues to run (cycle), you may have had some paper blocking it.
Hopefully this has done the trick and everything now works. If not, talk to the Staples store where you bought it.
Jan 08, 2014 | Staples Cross-Cut Shredder
When paper is fed into the auto sheet feed the left side of the paper feeds, but the right side is not feeding at all....resulting in a paper jam. You can hear the printer printing but the paper doesn't go...
helpful to know what kind of machine you have :\. In general one of the paper pickup roller pads is probably rotated 180 degrees out and not touching the paper, many rollers are triangular/square and have to be oriented correctly. Other causes are the plastic gears which if stripped means a junk printer unless its an expensive one. Stripped gears because someone pulled a jammed page out too violently is the usual cause. Check also for embedded staples/paperclips in the mechanism.
May 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
May 09, 2010 | Staples SPL1050LBRX (CrossCut) Shredder
Need instructions for SonyCyber-shot Dsc-S730
Hi Young man,
Download user manual for DSC-S730 camera from Sony Support.
Thank you.
Nov 21, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
Continually getting paper jams. Not picking up the paper. probably needs cleaning and maintenace. Bought at staples a couple of years ago. Where can I get service. Model is Intellifax 4750
Have you tried to clean the feed rollers yourself?
I would try cleaning the feed rollers before bringing it in for service.
You can slide the paper drawer completely out, and then look under the machine to find the feed rollers.
Usually they are Gray.
There is a chemical that you can buy at your local hardware store called "Goo Gone". This is a cleaning chemical that will clean the rollers and not dry out the rollers like alcohol would.
I hope this helps.
Good luck.
Mac =)
Feel free to ask more questions if you have any.
Mar 21, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Staple problem
pull about 1 inch of staples out of the cartridge, tear off the 1 inch so new staples are flush with plastic cartridge. Reinstall and make 10 stapled sets. By the time it tries to staple set number 3 or 4 you should start to see the staples working. It could take as many as 8 or 9 sets for the staples to advance far enough. Once it staples you are all set/
Mar 19, 2008 | Sharp AR-407 Copier
Canon P23-DHV Calculator Logo
223 people viewed this question
old marine
old marine
