Question about Bosch Axxis WTA 3510 Electric Dryer
Lint Filter Light Comes On Prematurely on BOSCH WTL5400UC Dryer
Despite cleaning the lint filter and the heat exchanger, following the instructions in the manual, and cleaning all the lint out of all the nooks and crannies I can find, plus mopping up any water found within the appliance we are getting the "Clean the Lint Filter" indicator within minutes of starting the dryer. Am I missing a sensor or do I have a failing sensor? I have also ensured that the air inlet is not blocked as the manual suggests. Does the heat-exchanger ever need replacing?
I would greatly appreciate any help you can give.
3 Suggested Answers
  • 351 Answers
SOURCE: bosch axxis WTL lint indicator problem.
it may be a sensor fault,most dryer inlets are from the back.if the internal ducts are blocked it can cause this broblem,sometimes the drain hose from the pump can get a hair ball stuck in them.you may have to dismantle the dryer to find the solution.hope this helps.
Posted on Mar 08, 2008
  • 7 Answers
SOURCE: Water builds up behind heat exchanger
I don't know if there is a cure for this. Bosch never answers my calls or my e-mails, but I have found that by blowing in the hose to disengage the lint collecting there and then sucking out the line will remove nearly all of the build up amd drying will resume.
Posted on Aug 30, 2008
WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Dryer will not heat. lint filter is clean. dryer runs fine bosch dryer nexxt 500.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Nov 08, 2009 | Bosch Nexxt 500 Dryer
Dryer not working, indicates "lint filter" When I try to use the dryer (Bosch Nexxt), i first turn the dryer to the setting desired (regular or perm press, and time) it immediately has the "lint filter"...
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Sep 01, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Jul 08, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Lint filter wanring signal
I posted in late December on the lint alarm and what I discovered was a bit alarming. (no pun intended) Lint had been accumulating on and around the heating coils used to dry our clothes. Some of the lint was burnt and the remainder, amounting to a small handful, was caught up in other area's around the lint sensor. After carefully cleaning the heating coils (with a tooth brush) and removing the rest of the lint and successfully putting everything back together, we have not had a lint alarm issue since. (Touch wood). No need to replace the lint sensor or any other parts. It was not that hard to take apart the back and remove the heating coils to clean, but it requires the unit to be unplugged, careful attention to what came off and where it goes back on. After what I found, I will be cleaning the heater coils out once a year. Which then raises the question. Should a person have to do this? The obvious answer is no! But from time to time we buy things that are not what we would expect and do what we need to do to make it work. From what I can tell, lint is getting past the lint filter and ending up where it shouldn't be. Hope this helps any of you that are having the same issue.
Mar 04, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Lint filter going off after 5 minutes then shutdown
Hello folks try this if you have not gotten this resolved. Your dryers have 2 sensor systems, the first one test the clothes for moisture, the second for the heat. The 1 sensor system drops resistance when the wet clothes are put in the dryer. the shutting down after 5 minutes and lint filter light coming on could be that the dryer isn't sensing the moisture. Now for the fun part, the entire inside of the drum and paddles is the moisture sensor. Try cleaning the inside of the drum with a cleaner to remove any detergent or fabric softner residue. This is crucial if you are using fabric softner sheets as they coat the drum. Also wash the lint filter with soap and water so the water goes straight thru instead of puddling up. Remember to also clean the condenser as this can trigger this issue as well. Hope this helps
Jan 02, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
263 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
