Question about Linksys Wireless-G WRT54G Router
I downloaded latest security software from apple. now my wireless linsys g wrt54g won't work. I can connect directly to dsl, but can't make any connections with the router. I reset the router since it wasn't recognizing my password. Now I'm stuck without anyway to send the signal through the router and actually have it work. (Used the linksys suggested no username and admin as password. No help).
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 55 Answers
Quality Security Devices is about app or hardware.
Quality Security Equipment is important for you phone.
Posted on Apr 16, 2012
    Genius:
  • 1,268 Answers
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default password is `admin' (optional) and username is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Posted on Oct 06, 2009
The internet connection is fine (DSL AT&T).
1. You may have a an IP address conflict.
2. check the device connected to the router
all computer need to be connected at the same time.
3. Bring all the computers up one at a time and this should resolve the address conflict.
May 16, 2010 | Linksys WRT54GX4 WIRELESS 802.11G...
About a week ago my HP Pavilion DV4000 couldn't pick up my wireless linsys G router and said that no wireless connections were found. I had to use a wireless B card I had lying around but still having...
You are using a B wireless adater on windows XP computer.
Tere might be adapter utility installed on your computer. You can use that software to connect to the wireless network or you can switch over to windows software to connect.
It will be better if you use the WINDOWS XP to connect to the network.
Check the wireless settings of the router also.
Click here for more information
May 03, 2010 | Linksys Wireless-G WRT54G Router
I just installed dsl and want to use it with my existing router and the router doesnt want to work with the dsl ...help what do i do ???
First, make sure the dsl is working by connecting it to your computer directly.
Next, turn the router off, turn the dsl modem off, connect the dsl modem to the router. Start the dsl modem first, then start the router, then start your computer and try to connect.
Nov 07, 2009 | Linksys Wireless-G WRT54G Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Router and dsl issue?
I've run into this dozens of times. With DSL, keep in mind the software1.gif on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
Nov 06, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
167 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
