Panasonic PT-53WX42 53 in. Rear Projection Television
Problem for Panasonic PT-53WX42 53 in. Rear Projection Television
My 56" Panasonic crt tv turns on for a second then goes black
By sedwards886 on Oct 06, 2009
there's no picture and no sound. red power light flashes. do I need a new tube? how much is it?
Best Solution
posted on Oct 07, 2009
Very Helpful)
Slinteriors
Rank: Guru  Panasonic Televisions & Videos  Expert
Rating: 89%, 3802 votes
Need to know how many times the LED is blinking to assist you.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
asnowman
Rating: 95%, 604 votes
Your symptom sounds like a damaged convergence IC.
This is a common failure for this particular television. The power light is blinking indicate a short in the power supply.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Was this helpful?
Yes
No
Popular Solutions for Panasonic PT-53WX42 53 in.
Questions and Unsolved Problems for Panasonic PT-53WX42 53 in.
Do you recommend Panasonic PT-53WX42 53 in. Rear Projection Television?
Answer
Answer
I noticed today that the bottom of my WD-60735 looks like a layer of something on the screen inside... (More)
Answer
I have a Panasonic clor projectio system tv. The colors are faded and have a orangy tinge. Model is... (More)
Answer
When I turn my tv on it only stays on for about 5 seconds and it automatically turns off.
Answer
Hi I have this Panasonic PT 53WX42 which is totally dead.When you first power on the relay clicks... (More)
Answer
My inlaws have a PT-53WX42 previously had a convergence problem. A repairman replaced STK-392-120... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
