Question about Microsoft Windows XP Professional for PC
Errors how can i stop errors when system boot ?
  • Michel Nelson Dec 23, 2007
    Hi please can you help me if you can
    when window start up it come up with a window errors dll fine is not runing
I to change spanish to english
Posted on Dec 23, 2007
    Master:
    Sergeant:
  • 482 Answers
Reinstall XP. You may need more memory. is this a new disk or a copyed one. just keep reinstalling it. push ship and let it install.
When i on my system its start windows and stop and shows hdd error press f1 continue press 2 del f1 i press its booting failed
Your Hard Disk Drive is crashing or has crashed. You need to buy a new hard disk drive, and then you will have to reinstall windows and start over.
Jan 27, 2012 | Mercury Computers & Internet
Hello, My laptop will not start the windows set-up/Fresh Install scenario. after the drivers get loaded and says starting windows it goes to the BSOD error Stop 0x0000007B, I figure this to be a MBR virus...
In Figure 2-2 you can also see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information:
•The stop error number, which uniquely identifies the error
•The stop error parameters, which provide additional information relating to the specific stop error number
•Driver information is available if the source of the problem relates to drivers
Armed with this information, you are able to search online to establish the problem and hopefully a resolution.
In addition to the information available on the blue screen, if the system is able to be rebooted after the BSOD, either normally or using Safe Mode, it is useful to take a look in the System Event Log and view the error message. For example, a faulty driver during boot up usually has the stop error code STOP: 0x00000050 and an Error EventID of 1003.
If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu.
To disable the system from automatically rebooting, take the following steps:
1.Click Start, right-click Computer, and select Properties.
2.Click Advanced System Settings.
3.In the System Properties dialog box, click the Advanced tab. Under Startup and Recovery, click Settings.
4.In the System Failure box, clear the Automatically Restart check box.
These steps can also be configured if the system is booted in Safe Mode. There are over 300 unique stop codes, and most are quite rare. The full list
can be found on MSDN within the Bug Checks (Blue Screens) reference at
https://msdn.microsoft.com/en-us/library/windows/hardware/hh994433(v=vs.85).aspx.
Jun 11, 2017 | Sony VAIO VGN-NS140E/S Notebook PC
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
Jul 24, 2010 | Acer TravelMate 2480-2968 Notebook
Stop error screen
If you have installed a new hardware or software, it may be conflicting with the installed program there by causing your system to dump it time the conflict occurs. You have to boot the system to safe mode and uninstall the new software or remove the new hardware and restart the system. Your system is supposed the boot okay.
May 26, 2010 | ASUS P4S800D-X Motherboard
System is wont boot
Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
Heres how to fix the issue
Download the software fix by clicking here.
Launch it after finishing the installation.
Click “Scan Now” button
Click “Repair Problems” button and fix 0x0000008e.
May 21, 2010 | HP Pavilion dv6000z Notebook
I am unable to boot up after running FIX-IT UTILITIES IT STOP SAYING CAN NOT FIND NTFR AND NOW READS DISK READ ERROR
try booting up with installation dvd. Can you try to boot up, hit f2 and go to bios settings?
Aug 27, 2009 | Computers & Internet
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
PC Tools stops at DEEP SCAN When I'm trying to scan My computer system.
This is PC Tools Spyware Doctor program? Try booting the computer in Safe Mode (press F8 during the boot process before you see the Windows logo and select Safe Mode from this list of options) and then running the scan. With heavier infections many cleaning tools can be blocked or have inconsistent performance.
Dec 07, 2007 | Computers & Internet
Error messages
Try removing the jumper from the harddrive, then restart
or
Take the jumper off restart shut down and then put it back on again
or
remove the CMOS battery from system board and boot once after booting shutdown your system and insert the battery back, again start your system and press F1 next time it won't ask you for pressing F1. reset your BIOS after that (time,date,etc.)
Try these one should work.
Please let me know.
Dec 01, 2007 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
