Question about Samsung Digimax A7 Digital Camera
My camera fell and it will power on - Samsung Digimax A7 Digital Camera
Canon power shot sd 750 fell on the floor and is the lens are stuck open and keeps giving me a error for lens. the lens part fell so the lens now are uneven. is there any way i can fix this?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 11, 2011 | Cameras
My DSC-T10 Sony Digital Camera fell down and now the new pictures taken are coming Blurry (hazy). My old pictures in the memory stick shows perfect. Please advise what could have happened.
Based on the information you've provided, it seems that the Lens Mechanism of the Camera is damaged when it fell down. The Lens of the Camera is not focusing properly while capturing the images. As the issue is with the lens mechanism, the previously captured images are displaying normally. I suggest that you try resetting the Camera and check if the issue can be resolved.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Apr 01, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
Not powering
Hi ,
My camera fell down while taking photo after it is not powering on
Oct 12, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
Photosmart M407 Digital Camera: power switch fell off...
Do you mean you can no longer power the camera? did you drop it? get in touch have got spares for this camera.
May 17, 2010 | HP Photosmart M407 Digital Camera
Camera FELL AND WON
the part which comes out when the power is on might have got stuck .. try repairing it .
Apr 09, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Canon S2 IS - Camera won't power on.
http://www.fixya.com/support/r3771170-phone_water_damage
Dec 28, 2009 | Canon PowerShot S2 IS Digital Camera
My Canon Power Shot A1100 IS camera fell and now
There is no DIY fix for this problem, and attempting a fix is likely to worsen the problem and cause the camera to shut down. Sorry, but your situation calls for professional repair.
Oct 31, 2009 | Canon PowerShot A1100 IS Digital Camera
Fell on the pool but it's off when it fell and it turned on but later on it did'nt turn on anymore
The water inside the camera became conductive and did damage to components on the circuit boards, and possibly did some damage to some of the mechancial parts. The camera would have to be rebuilt.
From past experience this type of repair has not been worth the cost. I would shop around for a new camera.
Jerry G.
Apr 26, 2009 | Kodak Easyshare 1725043 M893Is Digital...
Power switch fell off & gone. Need new one
The Power Switch is part of the Rear Operation Unit. You can find this part here in Black or Silver.
The Power Knob is on top of the Power Switch. You can find this part in Black or Silver. Make sure you know if you need the Power Knob or the Power Switch.
Feb 20, 2008 | Panasonic Lumix DMC-LC33 Digital Camera
My pentax optio s has fell on the floor.
It is not likely that camera drop damage will be covered under warranty. But it never hurts to ask. Regardless, you will need to contact Pentax about repairs. Repair location information should be in the documentation that came with the camera. Their website shows service centers: http://www.pentaxusa.com/service/serv_servcenter.cfm Camera drops are not uncommon. Sorry to hear yours was damaged.
Aug 30, 2005 | Pentax Optio S Digital Camera
Samsung Digimax A7 Digital Camera Logo
12 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
