Question about Jenn-Air JJW8130D Electric Single Oven
Oven door My oven door came off its hinge...how do you instal it back
I know on the older units it usually slides right back on. You might have to pinch the locking part of the hinge together, as it will have a spring that lets this happen. Once together, slide door onto hinge slowly. Too fast and it might slide past where it needs to go; if so, just pull back as if you are trying to remove for servicing. It should snap into place. Hope this helps. I might be able to tell you more if I knew the model#, type, etc.
Posted on Jun 22, 2008
Hi, I have just purchased a pair of hinges for my Lamona HJA3320 oven and they arrived in the "oven door closed" position. However, to fit to the oven they need to be in the "part open" position, and I...
i never worked on your brand but have installed hinges on other oven doors,install the hinges to the door,put the door back together,i have a piece of pipe that's hollow,have one person hold the door down while you use the pipe to position the hinge,just stick the arm of the hinge into the open middle of the pipe and you can easily move the hinge and set the lock on the hinge to the position you want it to be,maybe a car jack handle will work or a plumbing piece of pipe,doesn't have to be long like 2 ft. long this will give you the leverage to open it no problem,if you try to do it by hand use a towel or gloves so you don't tear up your hand.hope this helps it works for me.
Jan 14, 2018 | Ovens
Remove oven door from hinges
the door is removed with the hinges in place. with the door open, lock the hinge sections together with the little clips on lowest hinge section. When locked, lift up on the door (not the handle) sides, swinging it up until it can be pulled out. Install in reverse order.
Feb 17, 2014 | Thermador Ovens
Door to oven does not close completely - how do I access the door hinge to check or replace it?
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Jan 02, 2011 | GE JTP45 Electric Double Oven
I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
  • Screwdriver
  1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
  2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
  3. Step 3 Place the door on a flat surface such as a table or the floor.
  4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
  5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
  6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
  7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
Regards
Iversh
Jul 24, 2010 | Ovens
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
Oven door removal and installation please. Simpson Neptune
open oven door to first 'notch' pull door straight up off of hinge levers.maintain alignment of hinges to aid in replacement.
if they 'snap' back to closed position,pull them out equally to replace door
Oct 17, 2009 | Ovens
How to remove door for whirlpool oven RBS305PDB2
open the door about 1/3 of the way and lift it off the hinge pins. it helps to have two people do this. when it is time to replace it, put the hinges in that 1/3 open position and slide the door back down on.
Oct 02, 2009 | Whirlpool RBS305PD Electric Single Oven
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
How do you install oven door on Beaumark Model 13340-1
Figured it our by myself - the 2 hinges (long and short have to be "hooked" together and then inserted into the oven hinge opening.
After I solved it found the solution is also posted on appliance repairs- how to remove and install oven door. It also posts pictures.
http://www.applianceaid.com/oven-hinges.html
Jan 23, 2009 | Ovens
Jenn-aire JJW8530dds
It might be because when the door was completely removed ( which they do rather easily for repairs and moving) it wasn't put back properly.
I would suggest you remove the oven door and re install.
You do not remove any screws or anything like that to remove the oven doors.
When you have the oven door open squeeze each hinge and shift then both outwards it will release the door from the hinge, the hinge stays on but the door will slide off the hindge. Afterwards check the alignment and reinstall the oven door
Aug 02, 2008 | Jenn-Air JJW8330D Electric Single Oven
Jenn-Air JJW8130D Electric Single Oven Logo
67 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
