Question about Linksys Wireless-G WRT54G Router
Wireless router got a good signal on lap top but lap top ill not connect to internet wireless router comes up untitled and my computer will conect lap top will connect through a cable through modem
  • wiloak Dec 26, 2007
    I have a similar problem where I have had the wrt54g for the last 2 years with no problems and now for no reason I can not connect wirelessly with any of the 3 laptops previously connected without problem. I can connect via cat5 cable directly to to router but not wirelessly. The laptops "see" the router but wont connect. I have 2 running xppro and 1 running vista.
  • Whyfi Jan 05, 2008
    WRT54G wifi connection to Gateway laptop with XP Home edition stopped working after 1 - 2 years. When I click on available network connections and "Connect" it gives the "Acquiring network address" message for a minute or two, then "Limited or no connectivity." I can connect to internet when plugged in directly from router. Other Sony VAIO connects in Wifi mode no problem. I had WPA set up and changed it to WEP. I don't know what else to try as the wifi and router work for other laptops. Can the Gateway's Wifi ability be "broken?"
Solution for Whyfi: After resetting about 5 times and changing security setting (disable / enable) a few times, it works now...
Posted on Jan 05, 2008
Iam trying to set up a wireless security on my linksys.I put admin and it did not work as a password.I have set the security pass word and did changed my mind after.
Posted on Dec 24, 2007
    Sergeant:
  • 239 Answers
Do you see a little monitor Icon in the lower left bottom. If so go ahead and right click on it and select wireless connections , If not open network connections, now you should see detect wireless networks, Click on that,( IF SO ) Now you should get a window that shows your wireless connections, Select the network you have by clicking on it, and then in the lower left of the window Opened you should see a connect button, select that, you should be able to go online now if not let me know, there are some other things we can try to get you up and running just write back here if it does not work and as soon as I get this I will get back to you. I am sure its nothing we can't solve. Ok thanks bear001
  • bear001 Dec 24, 2007
    I meant lower right hand side not left sorry
    I sorry I meant the lower right not left on both so sorry hope that works
Trying to conect laptop to virgin media with netgear wireless adaptor the signal is strong but could not conect windows say to contact provider provider gave me number to enter 192.168.0.1 now i am lost
The router is not connected to the internet via Virgin media.
Your computer is connected only to the router wirelessly, that is why it says contact your internet supplier on how to connect the router successfully!
Jan 12, 2011 | NetGear WGR614 Wireless Router
all that you need to do is to delete the preferred networks list from the computer,
and try to scan and connect to the network again....make sure that you are typing the correct security key.
still if the problem exixts, then add the network manually...the problem will get off for sure....
also if there is any facility like wi-fi protected security is enabled in the wireless router, go ahead and disable it...
Apr 03, 2010 | Linksys WRT54G2 Wireless Router
I am unable to connect to the internet using a wireless connectio
I would first try and reset the router, then run a Repair on the connection again.
If this doesn't work, try going into the Device Manager and removing the Wireless Device. Restart the computer and reinstall the Wireless Device drivers.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 26, 2010 | Intel S6240 Notebook
When i unplug lap top lose enternet conection
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 23, 2010 | NetGear DG834 Router
Cant connect belkin 54g router to internet
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 07, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Cant connect to the internet on my lap top
first thing is to identify the wireless settings of the router,you need to identify the wireless name (SSID), channel and the encryption you are getting from the airlink router. Next is to make sure that the wireless computer has enabled wireless signal/ or the wireless is on.
after that, you may connecting wirelessly to the computer, right click wireless connection and go to view available wireless networks, try to connect -input the encryption key from you wireless router or password and hit connect.
Jun 28, 2009 | Airlink AR430W Wireless Router
Connecting my new laptop to the internet
There is a wirless icon in the botom right corner of the screen right click it and say view all wirless networks. lock for the one you own say conect it might ask for a WEP password which is located on the botom of the router that is if you did not change it from the defult.
Jan 03, 2009 | Zyxel Prestige P-330W Wireless Router...
Can't get internet connection to my lap top.ps i have a desk top.
Is your laptop wireless adapter correctly configured? It may be set to only recieve certain types of signals (802.11b, when you may beed 802.11g etc), so check if the configuration of the laptop matches the configuration of the router.
To test if the laptop can get internet at all, try to get to a wired internet line (your wireless router may have some Ethernet ports on the back; laptops usually have Ethernet connectivity), just incase your laptop is set to block all internet signals coming in.
Hope this helps!
Dec 27, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
102 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
