Question about Espresso RMI La Cimbali Espresso Machine
How do you change the dosage time on a Cimbali Bistro espresso machine
    President:
  • 1,618 Answers
You can do it one of 2 ways, if the machine has a display then you can go through the program mode by removing the face cover on the display and pressing the programing button then navigating to the dose setting menu, then select a button and change the numbers there. Note the numbers are not ounces rather flowmeter cycles.
Second way is to hold down the stop button for 8-10 secs you will notice the lights flashing and you will hear a faint beeping every second, press the button to program then hit stop when you get thew correct volume, when done with all buttons hit the stop again.
Posted on Oct 07, 2009
La Cimbali M30 Dosatron Espresso Machine dosing buttons not functioning, how do I fix?
These are membrane pads that do require a full replacement as they are all attached on a sheet. Some of the optional buttons are on separate pads but still grouped together.
check cimbali.com (for current USA contact)
Dosing can be change though some machines may require a service key.
you can also try (which is closer to your time zone)
Hawaiian Paradise Coffee 808) 682-4422
ukebo57
Jan 25, 2013 | Espresso RMI La Cimbali Espresso Machine
I need to see a wiring diagram for a la cimbali espresso machine m2
These super automatics really require a service tech. Please contact your vendor or cimbali.com for current contacts
ukeboy57
Nov 17, 2012 | Espresso RMI La Cimbali Espresso Machine
La cimbali m31 bistro
It sounds like one or more of your gaskets has failed it depends where its leaking and steaming from.
I find a parts list is helpful in identifying where the problem might be the best I could find on the net for yours is a austrralian website that has on line parts diagrams apparently a lot of the parts are used in a number of their machines the link is
http://www.coffeeparts.com.au/cimbali/cimbali-spare-parts-1
May 31, 2012 | Coffee Makers & Espresso Machines
La cimbali m32 bistro overheats How do i fix this?
Hope it would help by follow the step on this link: http://www.hwl.dk/product-images/mespres32_man.pdf
Apr 14, 2012 | Coffee Makers & Espresso Machines
I need service manual for cimbali m22 plus
call your vendor and check with cimbali.com for current contacts.
ukeboy57
Jun 08, 2011 | Espresso RMI La Cimbali Espresso Machine
La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
May 18, 2010 | Espresso RMI La Cimbali Espresso Machine
I have a La Cimbali Domus classic servicing required
check cimbali.com for current contacts.
youtube; ukeboy57
Nov 10, 2009 | Espresso RMI La Cimbali Espresso Machine
La Cimbali Owners Manual Wanted
Operators manual only describes how to install and set up. The Technician's manual is translated from Italian and is purposely vague. (Cimbali wants you to go to tech school). Suggest you ask for a annual preventive maintenance from your local service Cimbali dealer. You may need an overhaul/de-scaling which will be very expensive (+$1,000) in labor and parts. (mostly labor as it takes us about 40-50 hours per machine.) Hopefully you just need to change the worn parts in both groups and a vacuum valve. Good luck!
Mar 13, 2009 | Espresso RMI La Cimbali Espresso Machine
Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
Aug 12, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Espresso RMI La Cimbali Espresso Machine Logo
333 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Mohamed Ismail
Mohamed Ismail
John
Mark Cheong
Mark Cheong
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
