Question about Acer Aspire One Netbook 8.9" Notebook
Did not start successfully. tries to start up, but get sent back to inititial: Did not start successfully screen?
    President:
  • 2,600 Answers
Try this....
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 06, 2009
HAVE RED SOS SIGN ON MY BLACKBERRY
I solved this issue for one of my customers . Here were our steps:
Options > Network & Connections > Mobile Network > Network Technology should be sent to 1xEV.
As soon as we switched it back the SOS disappeared. SMS started incoming immediately and voice tests were successful!
Jan 11, 2016 | Blackberry 9720 Smartphone White, Factory...
KitchenAid Double Oven LED Blank
These ovens are made by Whirlpool. The electronic control board is notorious for going bad. If it is the one I am thinking about it is probably no longer available and will need to be rebuilt. I have had good success with Corecentrics Solutions. A google search will bring them up. I sent off the board and a rebuilt one arrived in about a week. Much cheaper than the original board too.
Nov 26, 2013 | KitchenAid Ovens
Broken screen on momo 8
Try http://www.chinamidparts.com
25 quid to UK for parts inc free postage. 3 weeks delivery claimed.
I've sent off for one myself. Will report success in a month or so.
Martin
Jan 26, 2013 | Umi Ployer MOMO8 Dual Core 8 Inch IPS...
I have i dell inspiron 1525 but its operating system (vista basic 32 bit) corrupted. how and where can i get a free download of vista basic 32 bit because i dont have the original disc, so that i can...
Hi!
You can try using the recovery partition of the hard drive of the computer, if the recovery partition is still alive, it will let you reinstall Vista back, you can inititiate this by pressing CTRL + F11 key whhen you turn on the computer. There will be no idication of recover on screen instead it looks like windows is startin to startup recovery. In the window you see below the active startup recorey there is, in blue, something like advance recory or something like that. When you press it you will see dell factory recovery. Hope this helps.
Apr 15, 2011 | Dell Computers & Internet
The application failed to inititialize properly (0x0000005)
may i know what application you trying to run? This may have caused by a conflict with Application and Device Control.
If you have further question, you can keep in touch my me just click here.
Jan 30, 2011 | Computers & Internet
My HP Pavilion a1101n will not start up properly. It sends me to a window that says sorry for the inconvenience, but Windows did not start successfully. A recent hardware or software change may have caused...
Power down. Power up. Before the Windows screen appears, Tap < F8 > during startup until the Windows Advanced Options menu appears. Press < Down Arrow > until Repair Your Computer is highlighted, and then press < Enter >. In the System Recovery Options window, click to select your language, and then click Next.
May 29, 2017 | HP Computers & Internet
When initially turned on TV will alternat between picutre & black
When the tv goes to a black screen does the sound remain on? Also,if you listen carefully can you hear any arcing noises in the back of the tv?
Aug 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Black screen comes up "windows did not start successfully...." choose from safe mode, safe mode with networking etc Last known Configuration or Start Windows Normally. Computer then tries to...
You should opt Safe Mode:
  • On the black screen just navigate throug up and down arrow keys.
  • Goto Safe Mode and press enter.
  • It will boot your system in safe mode.
If the boot is success full:
  • try to remember any software or hardware you recently installed/change. Then remove/uninstall that software/hardware. Also remove some device driver like Video/Audio driver and make re-start. and try to normal boot. If success then install your audio/video.
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
Apr 20, 2008 | Computers & Internet
Problem with Asus notebook
It is your laptop screen. You may have a cooling problem,screen or motherboard. Since this is your 3rd time trying to get this repaired. I would speak to a manager explain what has happened and demand a new replacement laptop.
Jan 14, 2008 | Computers & Internet
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer Aspire One Netbook 8.9" Notebook Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
