Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE LSS25XSTA - side by side with ice dispenser. Crushed ice is dispensed very slowly. Have removed and defrosted / checked the tray mechanism with no obvious problems. The dispensing speed is unusable - is this ''normal'' or is there something I can do about it?
  • 146 Answers
SOURCE: Ice dispenser only dispenses crushed ice
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Posted on Dec 26, 2007
  • 184 Answers
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
Thanks, bro. Right on with that fix.
Posted on Apr 21, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Ice cube dispenser will only deliver crushed ice
Remove the ice bin, and in the back of the freezer you'll see a square opening with a white plastic piece inside. When you dispense cubed ice this piece lifts up, lifting the long metal rod that runs along the bottom of the ice bin. When that rod lifts it opens the ice flap at the front of bin, allowing cubes to be dispensed. If the flap is not open, the cubes will be ground against the cutters and you will get crushed ice.
Here's what you can do to make it so that you always get cubed ice. Take a wine cork and stand it on end. Using a good knife, I positioned the blade about 1/3 of the diameter from the edge and cut all the way through the length of the cork. Then remove the ice tray.
Now put your finger in the sqaure opening and lift up the white pastic piece. Slide the modified cork under the flap so that it is jammed into the raised position. (This is the position it should be in when you are asking for cubed ice.) Now slide the ice tray back in while using your left hand to push the plastic ice flap at the front of the tray to the left side (again, the position it should be in for delivering cubed ice). Peer under the tray while you're slowly sliding it back in so that you can see if the metal rod connected to that ice flap successfully slides into the square opening at the back. If it can't slide in above the cork-raised plastic piece, you may need to pull the cork back out and trim a little more off it.
This worked for me... I can't get crushed ice anymore, but I've only needed crushed ice once in the 16 months I've lived here so that's not an issue for me.
Apr 02, 2010 | GE GSS20IEP Side by Side Refrigerator
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker only makes crushed ice, no cubes I have the same problem... The same switch works fine for the crushed ice and water setting but will not dispense cubed ice. It only gives crushed.
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
May 27, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice dispenser will not switch back to cubed from crushed
Mar 15, 2009 | GE Refrigerators
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispensing problems
Check that the crush mechanism is not jammed with ice. That could prevent it from disengaging.
Dec 31, 2008 | GE GSS25LGM Side by Side Refrigerator
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
Nov 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
