Question about Casio FX-300MS Calculator
How do I change this calculator from radians to degrees.
  • Casio Master
  • 7,993 Answers
Here is a clipping from the manual for the FX300MS, that will certainly help you to change the angle unit.
Posted on Oct 08, 2009
Ti-nspire cx CAS gives answer in degrees even though it is in radians mode.
When you set some configuration parameter you must scroll down the setup until you reach the OK button. Press the OK button to validate.
Oct 09, 2014 | Texas Instruments TI-Nspire CX CAS...
My calculator is not computing sin^-1 or cos^-1 correctly, I put sin^-1(0.184) in and it came out with 10.60283... when I should be getting 1.39. HALP?
When the angle unit is in radians
sin^-1(0.184)=0.1850543940 radians
When angle unit is in degrees
sin^-1(0.185)=10.60283581
Your calculator is calculating the functions correctly)
In the following screen captures the sine of the values is calculated with the unit specified inside the formula (degree symbol and radian symbol are inserted to show you the unit). In the last calculation the value of the sine is practically 0.184
Remember that when angle is in radians, for very small angles (less than 10 degrees), sin(x) and tan (x) are about equal to the value of the angle in radians
Mar 25, 2014 | Casio FX-115ES Scientific Calculator
How do I change the mode from Degrees to Radians?
Press the DRG key (top row) to cycle through the three angular modes.
Sep 18, 2012 | Texas Instruments TI-30 XIIS Calculator
Whenever i put in sin or cos or tan on my calculator the wrong answer comes up, how do i fix this?
Most likely you do have the calculator in radians (or if you are working in radians, you have it in degrees). Press the mode button, move cruser down to "radians degrees" highlight degrees. and press "2nd quit". things sould be better!
Jun 03, 2010 | Texas Instruments TI-83 Plus Calculator
HOW DO I CHANGE THE RADIANS MODE TO DEGREE MODE BECAUSE MY CALCULATOR IS IN RADIANS AND I WANT TO CHANGE IT TO DEGREES
Turn calculator ON.
If you do not see icons, press MENU.
Use arrows to highlight the RUN icon and press EXE
In RUN application press SHIFT and SETUP
Use Down Arrow to highlight the line Angle
Press F1 to select Deg and press EXE.
This action will return you to the RUN application (main calculator screen).
Hope it helps.
Nov 27, 2009 | Casio FX-9750GPlus Calculator
How do you convert it from degree to radian mode
To convert a displayed number from degree to radian, press [2nd][DRG->] once. Each time you press the two keys in sequence you change from deg to rad to grad to degree and so on.
Hope it helps.
Oct 23, 2009 | Texas Instruments TI-30XA Calculator
On my TI 83 plus my sine cosine and tangent buttons are giving incorrect answers.
Alot of people seem to be having this problem. Angles can be measured in two units, degrees and radians. Your calculator is currently doing everything in terms of radians. I have an 84 but I'm sure the 83 is similar, go under MODE and look for Degrees and Radians and make sure you choose degrees. if you have to convert, 360[degrees] = 2* pi [radians]
(easy to remember, 360deg in a circle, 2pi radians in a circle)
Good luck
Aug 11, 2009 | Texas Instruments TI-83 Plus Calculator
Don't know how to change it from degrees to radian mode
if you press the |mode| button (at the top right of the calculator) until you see Deg Rad Gra on the screen (I believe 3 presses of the mode button) and just hit the number below the rad option on the display. This will permanently change it to radian mode until you repeat this step, or clear the memory.
There is also a way to change to radian mode for just one operation if you will be mostly using degrees for example
at the bottom there is a DRG> as a shifted function. I would just recommend changing it in the way I initially outlined as there is less room for error when making calculations.
Apr 22, 2009 | Casio FX-300MS Calculator
Radians and degrees flipped
reset ur calculator. press 2nd 6 F1 3 Enter. Note that all your data will be gone
Jun 07, 2008 | Texas Instruments TI-89 Calculator
TI-89
Angle mode, Degree/radian setting, Chapter 2, pg 53 (pg70 of 623) Tan instructions pg 510 (appendix A pg 527 of 623) Here's your manual, download this file: http://www.ti-89.org/uploads/ti-89-manual.pdf
Jun 07, 2007 | Texas Instruments TI-89 Calculator
Casio FX-300MS Calculator Logo
674 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
