Washer's hot water valve has water hammer
The hot water valve on our Kenmore Front Loading washer 417.43042300 has water hammer.
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Loose spring within valve..Fit new solonoid valve...You could try reducing water pressure slightly
Posted on Oct 06, 2009
Kenmore Elite front-loading washer
What the heck it this garbage about washers
Feb 11, 2014 | managemylife.com
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore top loading washing machine is leaking from the bottom. The water is dripping from the bottom of the front panel. What needs to be fixed and how do I do it?
This symptom usually indicates that you have a failed inlet solenoid water valve assembly. Completely unplug the washer from the electrical supply and see if the water stops filling. If it does, then you likely have a control board failure. This is rare but possible. If the water continues to fill with the washer unplugged from electricity, I recommend shutting off the hot and cold water supply faucets behind the washer. It is likely that the water will stop filling the washer. This would indicate that you have a failed water valve assembly.
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Getting only cold water to my washer; hot water is not there
Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
Mar 29, 2009 | Kenmore 20722
Leaking washer
Replace the valve, or if new, have them do it. You are sure it is the valve and not where the hot warter hose attaches? Confirm by hooking up hot water under preasure to see if that seals itself.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer
sounds like you have a bad water valve,,either that or a bad water temp select switch,(doubt that). way more common is a bad water valve.
Mar 22, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Dec 27, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
234 people viewed this question
Top Washing Machines Experts
