Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore series 110 model 80
During overload the drum began to wobble. Now I believe it is no longer atatched ( drum ) and it wont stay level during spin. everything else works fine. The drum is off center and during spin cycle it wobbles a lot and is noisy / sounds like drum is hittin the side of frame
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Two things to check are the Basket Drive Block and the Brake and Drive Tube.
The clutch on the transmission drives the Brake and Drive Tube when in spin mode, the Basket Drive Block transmits the spinning of the Drive tube to the tub.
See the following description of how to pull the cabinet, agitators, drive block and drive tube.
As an aside, you don't need to buy a special spanner wrench to remove the Drive Block Basket Lock Nut. I found that by using a short 10" pipe wrench, opened all the way and hooked over one of the tabs on the nut, and giving it a short whack with a hammer, the nut will come loose.
Check that the basket drive block fits on the drive tube with the two tabs on the drive tube fitted into the slots in the drive block.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Posted on Oct 06, 2009
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
80 series model#26852504. just replaced the trans and now i have to open and close the lid to get the drum to spin
I don't get cold water in the washer. I even changed my water inlet valve. I don't know what else I have to look for. Please post me the solution. The model is Kenmore 80 series-110 26852504
May 17, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
What is the capacity of my Kenmore 80 series Model 110 washer?
Sep 08, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore, Series 80, model 110-62852101 heats, hums, but the drum does not turn. The drum is not frozen - I can rotate the drum. Reading the posts below, I believe I need to check the belt - but it is...
You are correct in thinking its the belt, that is the likely culprit, although it could be the motor, but usually the motor would give some warning before going out...humming, slowing, etc. In order to get the front panel off, you will have to first get the top off. (The top snaps over the front panel).
Jun 21, 2009 | Kenmore 64852 Electric Dryer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
310 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
