Question about Toshiba TLP-XD2000U Mobile Projector
The projector works for awhile and then seems to overheat and then shut off.
  • 2,237 Answers
Clean out the projector with canned air and check the fans. it needs to cool down and dust keeps in the heat. if you still have the same issue, it may not be a temp issue, but a power supply issue.
Posted on Nov 11, 2009
My projector worked fine for 2 years now it overheats it seems and shuts off i put a brand new lamp in it it still does it after 5 minutes or so
cooling fan , I wish they'd include a new fan as well with selling ya a new bulb , but last they don't , I find many times the cooling fan goes and that's what makes the bulb go (heat)
Feb 26, 2016 | Office Equipment & Supplies
Projector runs for 5 minutes then overheats and shuts off it is a wll-miount model not one that hangs from the ceiling UF55
it seems that the lamp is not good
the ballast is good,I think
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 13, 2014 | Smartboard Smart Board UF55 Projector Lamp
Vacuum runs for awhile and then shuts off
This sounds like an overheat issue. I suspect that something has restricted the air flow. Air flow is required for function and to cool the motor. if the air flow is restricted a thermal limiter opens the circuit, rather than have a fire.
Mar 04, 2013 | Proteam ProForce® 1500XP Bagged Vacuum
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
Projector starts the goes off by itself.
Check the fan is working could be shutting down cause overheat
Oct 16, 2012 | Sony VPL-ES7 LCD Projector
Our HC 6800 projector will work for about 10-20 minutes before displaying a solid red screen and shutting off.
Projectors shut off when they overheat. They overheat when air does not move through the projector cooling it. This happens when the fans are not working or air filters/vents are not working.
Check to see whether the fans are working. If they are working, open the top cover and see whether air filters/vents are covered with dust. If so clean them.
Sep 26, 2011 | Mitsubishi HC6800 1500 ANSI Lumens 3LCD...
The projector comes up then runs for awhile then shuts down. I checked the fan and that seems to be ok. I also checked the capacitors and those are good as well. I have summarized the the ballast component...
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector ro provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 20, 2010 | BenQ MP720p Multimedia Projector
Projector turns on for about 30 seconds then shuts down. the fan kicks up high, and led light flashes yellow for about 4 min until the fan shuts off. does not feel hot so overheating does not seem to be...
if the lamp lights and then shuts down, replace the lamp. it's at the end of it's life. to rule out overheating, blow the projector out with canned air. dust retains the heat that the projector is trying to expell. also see if all of the fans are working. if you do get an image for a short time, try to get into the menu to reset the settings to factory default. lastly, if all else fails, you have a ballast issue. unfortunately, infocus no longer sells parts for this model.
Nov 28, 2009 | InFocus LP 630 Multimedia Projector
Projector overheats after 30 minutes and shuts down
Is the fan in your projector still working in high speed or not spining?
Dec 15, 2008 | Sanyo PLC-SW30 Multimedia Projector
XB31 projector overheat
Hi sun_md
This sounds like a typical temp. sensor that is faulty.
If you take off the top cover of the Projector and follow the cables from your fans to the Mainboard - you'll find a smallish board that regulates the heat of the Projector. You will also find another sensor on top of the lamp housing.
Try replacing the sensor that goes with the fans first , this is normally the one giving problems.
Good luck and thanks for using Fixya !
May 22, 2008 | HP Digital Projector xb31 Multimedia...
Toshiba TLP-XD2000U Mobile Projector Logo
143 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
