Question about Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000
6000w gas generator putting out low voltage
On 110ac outlet only getting 35v ac
    President:
  • 1,564 Answers
Your voltage regulator is at fault. Make sure you replace it with the exact same brand name and serial number or you will burn out the generator.Thank you, Dana
Posted on Oct 06, 2009
What is the recommended oil capacitiy for a pulsar 6000w generator
This unit show to have a 10HP gas engine and thus should have a dip stick where you add oil. Guess 10HP gas engine 1.0-1.5 qts?? You can always drain it and measure. Than add it back...Good Luck
Jan 01, 2017 | Electrical Supplies
I have a Wacker portable Gen gs 5.6 It runs good but it also don't put out power ether
I suspect the inverter module has failed. The module failed on my kipor gen and produced the same problem, ie no A/C outpu. Module was about $300 for Kipor. Fitted myself, problem solved.
Dec 06, 2014 | Electrical Supplies
How to test the electrical system of the generator for free
Ez test to determine if stator wiring is ok. This test works on generators that have two sets of 115v plugs and 220v plug. Use a 12v, 1amp ac power supply ( smaller ac power supply should work ok ). With generator not running, apply 12v to one of the 115v outlet plugs. Now verify 12v output voltage with meter at another 115v outlet on generator. Also verify that there is about twice the voltage at the 220 v outlet plug (should be about 20v - 24v) . If the adjoining 115 v outlet plug has no output or very little voltage or if the 220 volt plug has no output, most likely stator is damaged or breaker is off. If the stator is shorted voltage reading will be very low and power supply will heat up. If stator is open, there will be no voltage at second 115v plug or 220 v plug. If voltage is ok at the other outlet plugs as per test above then most likely problem is with voltage regulator, or brushes not making contact or armature winding open or just needs to be energized. Unplug the 12v power supply after test to prevent it from overheating. Most generators have two 115v windings that together power the 220v plug. When you energize one of the windings with the 12v power supply, the second 115v winding will be energized also and give you a voltage reading about equal to 12v. You will not damage the generator with this small voltage being input thru the plug. Good luck
Oct 14, 2014 | Electrical Supplies
Photocopy canon not working ido why irc2380i
The problem with using a generator with a copier is that you are not using a constant wave length & a constant voltage. It is not a constant and level voltage as compared to a outlet. Also, there may not be enough watts. Copies today need a constant watts & voltage to work correctly. The PCB are very sensitive to any voltage drop at all.... Mostly 5 & 12 & 24 volts DC. A generator dos not produce a clean AC voltage. It's OK for a light bulb or a frig or micro wave...... Good Luck
Dec 19, 2012 | Office Equipment & Supplies
Briggs & Stratton 12KW Model 040229 LPG Generator. 96 Volts @ the 120 Volts outlet, When I turn the house 2 Ton AC voltage increase to 106 Volts.
Can you manually adjust the voltage on the generator without load?? If you have 120/240 60hz output on it and you are not overloading the unit (amperage), then it may be as simple as adjusting whats called your gain setting for your voltage regulator. Obviously you are seeing what happens when it is set too low. Trying raising that setting until it becomes unstable then back it off. Unstable meaning voltage starts jumping all over.
Jun 27, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
Aug 17, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
No electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Jun 09, 2009 | Porter Cable Electrical Supplies
Running but putting out power
You need to remove the cover where the outlets are at and measure the voltage before the breaker. There are no fuses on the output side of the genset only breakers. If breaker is fine but still no output, try flashing the fields with a 12 volt battery. If voltage increases then your voltage regulator is bad.
Apr 15, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000 Logo
386 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
