Unable to secure lock on door
Refitted glass on washing machine door, but the lock doesnt seem to be working not sure if I'm putting it on correctly.
    Top Expert:
  • Washing Mach... Master
  • 79,865 Answers
Make and model number of the washer please.
Posted on Oct 06, 2009
Prepare for moving?
Make sure that the drum is locked and if possible to tuck in thermocole or sponge so that the drum will not move along. also make sure the panel and door glass is protected, Tape with sponge on the panel and door.
Jul 05, 2012 | Washing Machines
The door on my fridgidaire atf8000fs1 sags so it doesn't shut correctly. I've had to order a new door striker since the last one broke off. How do I adjust it so it hangs correctly?
Frigidaire washer door sagging so strike and door lock not lining up correctly. After a period of time front load washer doors tend to start to drop below normal position. The glass in the front doors are very thick, heavy and only supported by plastic inner frame. This combined with continued opening and closing will over time make your front load door start to sage. Fortunately Frigidaire makes a door shim kit for this problem.
After you have ordered and received the shim kit part #137309800. Start with removing the three screws holding the door to the machine. Lay the door face down on a soft surface as to no scratch the front of the door and glass. Remove the screws securing the outer frame and with a very small flat screw driver shim it between the inner and outer panels. Make sure to note the position of the frame and glass. Next remove the inner plastic frame, you should have access to the hinge at this point. Install the shim kit according to the instructions that come with the kit. Reinstall the hinge, inner frame and screws. Install the door back onto the washer, your door strike and lock should line up in the correct position at this time.
i got this answer at http://www.appliancerepairquestion.com/2013/04/frigidaire-atf8000fs1-washer-door-not.html
Jun 19, 2011 | Frigidaire Affinity ATF8000FS
I have been putting my washing on a 40 wash and have been putting enough washing liquid in but my clothes just will not wash, i have felt the glass in the door but it doesnt get very hot, is my washing...
The hot water goes into the machine at a slower rate than the cold water does. Open the hot spigot (water valve) behind the washing machine all the way open, then open the cold spigot just enough to get the desired 'warm' temperature of the water going into the machine while the machine is filling. You may have to shut the door to allow water to flow. Remember that it takes a minute or so for hot water to reach the machine from hot water tank.
Dec 08, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Replaced door seal now door is difficult to close.
Sometimes, it is hard to close door after fitting a new seal.
Make sure you have got it fitted correctly round the flange on the front of the cabinet, and that the retaining clamp is securely fastened.
Try smearing the door glass with washing up liquid, this can help to close the door more easily
Please rate my solution.
Thankyou.
Feb 13, 2010 | Ariston Technologies Washing Machines
Water leaking from door
This video will show you how to change a door seal on this Bosch front loader washing machine to stop leak
we have all bosch repairs in our channel
You can get seals on eBay
Aug 29, 2009 | Bosch Washing Machines
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Indesit WIA 121 washing machine, front loader. The door lock led is continuessly flashing red even when the programme has stopped and the door is opened. I have to switch off at the main plug. Machine is...
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Apr 21, 2008 | Washing Machines
Hotpoint aquarius model wm62
Sounds like a faulty door interlock (quite a common problem)
UNPLUG POWER first, remove lid, remove screws holding door lock in place and lift lock assembly up, replace door lock, ensuring cables are replaced in the correct order. Refit and test.
Good luck.
Nov 11, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
