Question about Sony Televison & Video
SONY BRAVIA MODEL KDL-37S55xx Bought in August 2009 Annoying frequent sound distortion which detracts and spoils any viewing. What has happened to quality control at the factory ?
  • 54 Answers
SOURCE: How to improve picture quality?
are you using an hd source ? hd cable box, satelitte receiver or antenna with the digital channels programmed in. regular tv channels will not look as good as the picture you saw in the store when you bought it. they all use only high definition signals.
Posted on Jan 24, 2009
  • 267 Answers
SOURCE: How to improve picture quality sharpness?
PICTURE QUALITY IS USUALLY A FUNTION OF IT'S SOURCE. GARBAGE IN GARBAGE OUT.
IF YOU HAVE COMCAST OR SATELLITE AND IT IS NOT HD, YOU NEED TO HAVE AN HD SIGNAL FOR THE BEST PICTURE. THE BEST INPUT IS THRU THE HDMI INPUT. IF YOUR UNIT HAS A GOOD PICTURE WITH YOUR DVD UNIT, THEN THE HAVE A SIGNAL SOURCE ISSUE.
Posted on Jan 30, 2009
SOURCE: The TV has horizontal lines across about 5 inches
Horizontal lines are relatively rare problem in LCD TVs.
The likely problematic areas are:
1) The LCD itself (the micro ICs embedded into the LCD panel structure); that doesn't sound likely based on what you say, but it's not completely impossible. The bad news is it's mostly uncurable.
2) The power board A-1511-322-D G5
Power boards may sometimes cause problems with display, although rarely causing horizontal lines.
I wouldn't start looking here either, but it is certainly a problem to consider.
3) Main board 1-876-561-13 R1506072C
Slightly more possible and yet not quite likely. A high operating temperature and bad SMD soldering process may cause some soldering contacts on the main board to behave differently when the board is cold versus when it heats up. It is very common and may have all kinds of different effects on the TV and the screen.
One way to check for that is with a regular dryer..the process is explained in many other solutions at fixya and around the net, so I wouldn't repeat it here...but it takes time and patience.
4) The most likely place to start with is the T-Con / LCD controller
404652ASNC6LV4.1 M139.
I'd first replace that and see if the problem goes away.
5) There's a very minor chance that the LVDS cable that connects the main board with the T-Con does not make good contact initially and changes that as a result of getting hot. It's easy to just touch and move it lightly when the TV is still cold to see if it has an effect on the picture.
Sorry I couldn't just nail it for you, but that's the nature of the repair businss :-)
Bobby, www.coppelltvrepair.com
Posted on Mar 15, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
  • 25 Answers
SOURCE: Sony Bravia KDL series 52"
Check the fuses on the power board. there is one fuse on primary side and one on secondary side.
Take of back panel and follow plug into the tv.where it ends is the power board.always use caution.the capacitors in there hold high voltage even after unplugged for a couple of days.Discharge capacitors before servicing the board.
Posted on Jun 28, 2011
Distorted Colors on Sony Bravia KDL-40Z4100
T'Con board fault. For most Sony sets; T'Con is an integral part of the panel. It will be best to contact the authorized service center for Sony in this case. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 08, 2015 | Sony Bravia KDL-40Z4100 40 in. LCD TV
Sony bravia 22EX320 reboots and blink 8 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 19, 2014 | Sony BRAVIA KDL-22EX310 22" LED TV...
Sony bravia needs a new remote, have bought a
go on line to sony they will send new one at cost
Jun 30, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My Sony Bravia KDL-52V5100 has garbked sound or no sound intermittently throughout viewing. This happens on multiple HDMI inputs through both my upconvert dvd player and the HD cable box. It is corrected...
I'm seeing the same issue. Only thing I've seen is a firmware update but according to my Bravia, I am already running the current firmware.
Was considering doing the update anyway...re-installing it so-to-speak.
Having trouble finding any other resolutions online.
Sep 21, 2009 | Sony Televison & Video
Sony bravia dlp constant high-pitched sound
Could very well be the color wheel. This unit spins at 7000rpm and the slightest nick in the wheel can make horrible whine noise.
Aug 19, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony Bravia KDL 46V100 has only black & white picture-no color
I bought Sony Color Bravia TV 60 inch, moved with it Kenya, Africa, when i try to tune the color is not coming. I can only get black and white. Please anybody with idea on how to change it for Africa (Kenya). Model:KDL-52SS100. My e-mail. fredwagah21150@yahoo.com
Jun 30, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony Bravia KDL-40S20L1 lcd tv has no power no lights nothing
My Sony Bravia LCD Model-KVL37S400A is not getting the Main Power supply. The LCD is not getting switched on. When i am trying to switch on the set nothing is happening.
Apr 20, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
We lose audio on our Sony BRAVIA KDL-52W4100
This problem appears to be an issue with numerous Sony Bravia owners of the same model. Although still seeking a soulution, it would appear that our cable provider (Verizon) has replaced all of their components and the Geek Squad from Best Buy where we purchased the unit, points the finger at Verizon. None of our other Fios-equipped TV's exhibit this problem so I am glad we bought the service plan with the TV and will continue to seek a remedy.
Mar 04, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Televison & Video Logo
199 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
