Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
My hannspree HF 207 20 inch monitor I see is for Vista I have a PC Windows XP I need to get the driver so my sound will work. Anyone have any suggestions
Benimur
  • 6966 Answers
SOURCE: monitor
Should run normally and in my opinion doesn't even need the external driver. XP would allow several screen resolution settings and to my knowledge, this LCD is capable of max 1440x900.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 20, 2008
  • 44 Answers
SOURCE: No XP driver for Hannspree New york 19 inch monitor
Hi David,
Thanks for the comment regarding what type of computer equipment that you have. The integrated video card that you are using definitely is not designed for the widescreen monitors and will not work properly with the widescreen (as you have noticed). The solutions that you can use would be to get a non-widescreen standard monitor or install a new video card that has widescreen capability.
Hope that helps,
Take care,
Michael
Posted on Nov 17, 2008
  • 103 Answers
SOURCE: Hannspree 20
The driver that you are using for your video card doesn't support the resolution of this monitor probably.
Posted on May 04, 2009
Bat1956
  • 585 Answers
SOURCE: Hannspree HF237 23" Monitor
The driver files allow for windoze to set the monitor up as a plug-n-play device. However, you do not need drivers to set this up manually. If you will right-click the desktop and open the display properties, click the display adaptor tab, and uncheck the box that indicates to hide incompatible settings (I don't have windoze myself, but it's worded something like that) save that change and click on the monitor tab, then find a compatible setting for your monitor as indicated in the instruction manual, you can set it up to work as well as if it had the drivers.
If you have any questions, please ask.
Posted on Aug 06, 2009
  • 101 Answers
SOURCE: Hannspree HF 257 25
Is the power light staying on or does that go out as well?
If the power light stays on and if you darken the room, can you see a faint image still on the screen by shining a flashlight at it (close). If there is a faint image it is either the inverter or the backlight tube.
JC
Posted on Jan 31, 2010
Have Hannspree 205 HF running Windows XP Pro. Display has shifted to the right, and I can't get it back to center. Any suggestions?
Turn the Hannspree-brand monitor on using its remote, then press "Menu."
Press and scroll the down arrow button to highlight "Setting." Press the right arrow button to enter the "Setting" menu.
Press and scroll the down arrow button to highlight "Aspect."
Press and scroll the right arrow button to change the aspect ratio from "Auto" to "Full," "Normal," Panorama" or "Zoom," depending on the type of image that you want to see on the screen.
Press "OK" on the remote control. Press "Menu" twice to exit the menu settings.
hope it helps
Nov 29, 2011 | Hannspree Computers & Internet
I have a 22" Hannspree HF 237 monitor about a year
It is the inverter problem maybe it is loose or cold solder already. You better open the unit and look for the inverter section then re solder all leg parts there.
Regards;
votit
Feb 08, 2011 | Hannspree HF237HPB 23 inch LCD Monitor
My Hannspree 20 inch Monitor--The speakers want work--I don't have a driver--is there a website to download a driver-Windows Vista want recognize Monitor with the orginal Driver
we are using speaker building lcd but not need softwere for this. i think your computer sound setting is wrong.go control panel and look sound or speaker setting and correect it.
Oct 14, 2009 | Hannspree HG216DP0 22 inch LCD Monitor
Hannspree 23 inch monitor - driver problems
In my experience, monitors do not need drivers. Video cards do. Make sure your video card drivers for your computer are up to date. The card is what makes the picture on the monitor.
Jun 21, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Will Hannspree 20 inch widescreen work with Windows XP? Having trouble with a couple websites using XP and the drivers are for Vista.
Well in theory as a plug and play monitor it should work. However you will have to be wary of certain things such as whether the drivers will be essential for use. Best thing to do is check with your retailer first.
Jun 05, 2009 | Computers & Internet
Need driver for xp
There are no drivers needed for Windows XP, the default monitor driver will work fine.You may need to update your video card drivers if you are unable to use the recommended resolution.
May 01, 2009 | Computers & Internet
Hannspree will not supply XP drivers
i found a driver for my dell latitude d800 on dell.com. the download is r105341.exe. monitor works perfectly now.
Dec 15, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Hi David,
Hope that helps,
Take care,
Michael
Nov 16, 2008 | Hannspree HANNS-G 19" Widescreen Monitor
Monitor Drivers for Hannspree 199H
go to manufactor website and download all the driver's or use DRIVER MAX to find your driver's
Sep 06, 2008 | Hannspree HW191D LCD Monitor
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
1,726 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
