Question about Brother HL-4070CDW Printer
Jams a lot. i clear the jammed paper and seems ok for a while until it jams again.
  • 76 Answers
Check yor sensors and your pick up rolers,it must be clean and your seperation pad as well.
Posted on Oct 06, 2009
Kodak all in one 5500 states paper jam. Nothing works on it.
Nothing will work until you clear the paper jam. Even if there is no paper jammed, you need to open all the access doors and then close them again. The machine will do a reset cycle and then clear the paper jam message. If that doesn't work, then there is indeed a small piece of paper in there. Whenever you get a jam and yank a piece of paper out of the machine, you should flatten it out and verify there is nothing left behind and no bits missing..
Mar 24, 2016 | Kodak Office Equipment & Supplies
Carriage jam message...........comes on no matter what.........reset several times
Give a call to HP Tech support team they will try to resolve your issue. You can contact them (877-690-9305) Support For Hp Printer
Jun 21, 2011 | HP Photosmart C5280 Printer
My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Oct 20, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Error Message - Paper Jam
I had a paper jam. I removed the offending sheet of paper which unfortunately tore into 4 pieces as it came out. Upon piecing the sheet of paper back together - there is a small piece missing. I've checked the printer thoroughly - nothing can be found!
Feb 25, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP 7680 paper jam
I spent 21/2 hours with the HP tech support - with their recomendation to upgrade my 14 month old computer to the bigger model because the screen reads "paper jam". I have had this printer replaced once already, 1 week after I received it for a defective doc feeder. I decided to take things into my own hands - First of all, no paper was ever located in the paper jam area. Several soft resets by shutting down for 20+ seconds, then pressing #6 at start up resulted in any improvement - the screen continued to read "paper Jam....." the HP tech was unable to offer any practical suggestions.
I turned the machine upside down after removing the document feeder and examined the rollers at the back of the rear tray where the paper jam was supposed to be. I noticed that there was some black residue on the gears and although the machine was off and unplugged - the rollers / gears would not roll freely and seemed to get stuck. I cleaned them thoroughly with an old but clean toothbrush and water. (don't grease the gears - I've heard it eats the plastic) - until the rollers would freely roll when I moved the gray rubber rollers.
Returned the machine to correct position - and turned it on - "paper jam" message returned but the machine was sounding different than it had - so I did another soft reset (unplug from wall and printer for 20 seconds, then holding #6 for a few seconds while plugging back in and now I can print. The printer went through its maintenance cycle and did a realignment. I can print and everything is working fine at this time.
I hope that this will help someone. I couldn't find any information on how to repair the printer and HP seems to be all about producing junk and convincing you to "upgrade" at a cost of $2-300. When this one does finally go - I won't be buying an HP!
The 7680 jams a lot and the document feeder has a lot to be desired. It has trouble feeding straight and if there is a jam anywhere in the machine - it is always difficult removing the paper without tearing it and creating more problems and waste of time.
Oct 20, 2008 | HP Officejet Pro L7680 All-In-One Printer
Clearing paper jam
Solution Use the following instructions to clear a paper jam from the HP All-in-One.
  1. Press in the tab on the rear clean-out door to remove the door. CAUTION: Clearing a paper jam from the top or front of the HP All-in-One can damage the print mechanism. Whenever possible, access and clear paper jams through the rear clean-out door. Figure 1: Pressing the tab and opening the rear clean-out door c00444711.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the HP All-in-One. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are might occur.
  3. Replace the rear clean-out door and gently push it forward until it snaps into place.
  4. On the HP All-in-One control panel, press OK to continue the current job. NOTE: If the paper is still jammed, see the onscreen Troubleshooting Help that came with the HP Image Zone software.
  5. If the jam occurs again, check to make sure the paper type in the printer matches the paper type set in the printer driver properties
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Apr 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
Brother HL-4070CDW Printer Logo
865 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
