When I have a load in the wash it won't spin all the water out of the clothes.
  • Obertelli
    Obertelli May 11, 2010
    What is the make and model of washer? Do you get this problem on all wash programmes? Are you finding that it will drain and spin, but that it doesn't get as much water out as you expected? Was the machine previously working normally or is it a new machine? Note that no washing machine will spin ALL of the water out of the clothes, and most of them will auto-select a slower spin speed if set to delicate wash programmes even if you have a higher speed selected.
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Clean out the filter good luck..
Posted on Oct 06, 2009
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
How do you find something stuck between the tubs
Does it fill and wash, but just won't spin the clothes out? If so, you will need to replace the lid switch.
May 23, 2012 | Maytag PAV2300 Top Load Washer
My front load washer won't spin fast anymore, any solutions out there?
A leading cause of clothing coming out very wet(not spinning on high speed) is over sudding (too much detergent being used) to see if that is the case start the washer without clothes and see if there is build up of suds (there should be NONE) to clean over sudding run a cold water wash and add a cup of white vinagar that will clean the build up of suds
Jul 18, 2011 | Washing Machines
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Won's spin
We have not heard back on this in about a week. I'm presuming It's been repaired?
Jun 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer
Does washer spin without any clothes or water, try 'spin' only. If no, then u might have a loose connection to the motor. After u disconnect from the wall socket, see behind to see if all connections are ok. Do not over-load your machine, it could trip a switch which will stall things. Suggestions...
May 01, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
