Question about NetGear Computers & Internet
Adapter says i am connected to the router but no internet
Adapter says i am connected to the router. The signal is strong, but I cannot connect to the internet. but my computer says i am connected to the internet
    Guru:
  • 441 Answers
Try to find out if you require a proxy adress or if you were on a proxy, remove the settings and let the browser automatically choose the correct settings. Hope this helps you out.
Please rate!!
Have a nice day!!
Posted on Oct 06, 2009
Authentication error
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Jul 12, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Strong signal but can not connect
If you have a wireless router and it is connected to the DSLor cable modem then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Feb 21, 2012 | Computers & Internet
I cannot get internet on my laptop from an open access point with Time Warner internet
Though you are getting strong signals from the router, the router itself may not be connected to the Internet. The owner may leave the router on but power off the modem. It is possible that they may use the router for thier own private network with no connection to the Internet. When you connect to the router, check your network and sharing center to see if you see an X marked on the connection between the router and the Internet. If you do, the router is not connected to the modem.
Good Luck
C2Solutions
Feb 14, 2012 | Computers & Internet
I have just purchased a belkin enhanced wireless usb adapter N 150, i have managed to install the software and and connect to my router, the signal strength is strong, but when clicking on to internet...
Take an Ethernet cable, and connect one of the LAN ports on the router to the network-port on your computer. If you cannot get Internet access, then it is the router that is the problem, namely, that the 'WAN' side of the router has not connected to the Internet.
Oct 19, 2010 | Belkin (F5D7230-4) Router (587009)
2wire router/modem combo on main pc; trying to access with a Belkin enhanced wireless adapter on Dell laptop....strong signal, but no internet.
make sure you have the right key if you enter a wrong key it will act like its connecting up but wont give internet access
Aug 07, 2009 | 2wire (1000-400108-001) Router
My Linksys network adapter is very slow to connect
Ask them to review you connection speed to make sure your getting the speed you ordered. Linksys is usually pretty good. See if it's faster WITHOUT using the wireless (plug directly into the modem). If it is I can only think of two things... Ether you need to relocate your wireless modem to acheive a stronger signal OR if your signal is strong on your adapters end, you could always upgrade to a different wireless adapter that can handle faster conections.
Jun 27, 2009 | 2wire (1000-400108-001) Router
I have a WCG200 linksys but can not go onto internet.
from what i have read, your router is broadcasting a signal, and your modem has an open and active internet gateway.
pls make sure that the connection from the modem to the router are correct. the modem should be connected in the port with the label internet. you may have to reset your modem AFTER you have connected the wireless router to allow the router to be assigned an ip. now with the wireless router and broadband modem connected, you can connect to the network and access the internet. pls repost if you hit any snags
GOOD LUCK and PLS rate this post.
Mar 18, 2009 | Linksys WCG200 Router
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Low signal in the basement
maybe you should try to purchase a better wireless adapter,like dlink dwa-110
Jan 29, 2009 | D-Link AirPlus DI-524 Wireless Router
Connecting WUSB100 to Wireless G WRT54G
laptops have a wide range reciever built around the screen and tend to be far better than a normal usb dongle.
The fact that your pc is downstairs will be effected a lot because the signals from the router will be bouncing around in an area around the antenna and above, signals below will be effected by floors, doors and wall partitions.
Your best solution would be to place the router on a phone line downstairs and see if the signal is increased.
Aug 18, 2008 | Linksys WUSB100 Wireless Adapter
Computers & Internet Logo
279 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
