Question about DeVilbiss PLUS? Pressure Feed Spray Gun # JGA57010
Trigger pull is not as far as older model - DeVilbiss PLUS? Pressure Feed Spray Gun # JGA57010
  • Captaintess May 11, 2010
    what is the problem??? is the air/paint flow effected by this?
  • 98 Answers
Some models have less trigger movement than others.
at the back of the gun you have two adjusting knobs the lower one controls the trigger movement, which controls the fluid flow from the nozzle.
Posted on Feb 21, 2010
Bolt will not close
single action bolt try pulling the trigger as you push the bolt home
that will remove the obstruction to the bolt movement
Sep 11, 2016 | Marlin Model 60 .22 Cal Rifle
What causes the wire to feed continuously without pulling trigger
Is the wire also live without pulling the trigger ? It will most likely be the circuit board if it's a newer model of machine which has a component to energise the Motor , if it's an older model it could be a relay with contacts stuck together.
Oct 30, 2015 | Welding Tools
I need to adjust my trigger pull on a Ruger Model 77 rifle.
If you'll look up into the trigger assembly inside the trigger guard you'll see a set screw. I've got one of those old Rugers and supposedly that set screw is for adjusting trigger pull wt.
Nov 07, 2012 | Refrigerators
Lost owners manual, how do I advance the string
Hi don watts46...
Bump the rotating end of the trimmer on the ground while it is running and it will automatically feed the line out, the more you bump the more line feeds out.
Please take time to rate me
Aug 20, 2011 | Troy Garden
Stanley bostitch double fires. It is an older stick feed. Works fine when I hold the trigger and tap the tip. But when I press the gun into the wood and pull the trigger it double fires. Gun is older, but...
You did not list your model number, however most bostitch nailers use the tva6 trigger valve. As this valve wears it will be erratic. Examine the firing pin that makes contact with trigger. If it looks worn or wabbles from side to side, then time to replace. To remove valve first remove trigger by removing roll with 3MM punch. Next remove one or two roll pins just above the valve, also 3mm. With roll pins removed air pressure will pop out valve. Be carefull because valve can come out with force, use glove or rag to catch. Parts available at www.toolpartsdirect.com, or generic valve at www.ebay.com. Good luck
Sep 18, 2010 | Stanley Bostitch Coil Framing Nailer
Drill always starts at maximum speed
sounds like you need a new trigger, which you should be able to get at a Sears Repair Store/Outlet
Oct 19, 2009 | Craftsman 19.2V C3 DRILL/DRIVER
DeVilbiss  PLUS? Pressure Feed Spray Gun # JGA57010 Logo
214 people viewed this question
Top DeVilbiss Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
Lawrence Oravetz
Are you a DeVilbiss Air Tool and Compressor Expert? Answer questions, earn points and help others
