Question about KitchenAid Architect® Series II KBCS24RS Beverage Cooler
Kitchenaid Beverage Center light won't go outwhen I close the door. I've tried pushing the black button at bottom of unit and light still will not go out
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Short in freezer?
Lights inside a unit have nothing to do with the door ................the door closes the switch....with that siad there is either a 2nd switch in the liner or the single switch controls the door functions along with the lights (so the dispenser wont work when the door is open) has the switch been checked to see if it is good??
Posted on Apr 07, 2008
  • 125 Answers
SOURCE: Kitchenaid refrigerator side by side, refrigerator door will not close on its on like it use to. Model #KSRS25qDWH01 bought in 1996. If we give it a push it closes fine. But it use to close nearly b
order a cam and stop for the affected door. it is on the top of the hinge and the bottom of the door, you'll see the two pieces if you look where the door contacts the hinge, call a dealer for the correct part numbers.
Posted on May 05, 2009
SOURCE: I have a Frigidaire Beverage Center Model
I recently purchased a Frigidaire Beverage Center and had the same constant beeping issue as strivieri. I found my problem to be the door sensor. The door sensor is located on the lower bottom right of the unit and there is a metal plate mounted on the swinging door that is suppose to push that sensor in when the door is closed. However, this was poorly designed as it fails to do its task. I had a few adhesive floor protectors laying around that I used to stick to that metal plate that gave it the extra thickness needed to push in the door sensor when closing the door.
I hope this helps anyone else there having the same issue.
Posted on Jun 05, 2011
Kitchenaid oven won't turn on
FOLLOW the OWNERS instructions to TROUBLE-SHOOT (EG remove the door, clean it & replace it properly, etc.). On my model... check the center top for a simple switch lever... than gets pushed straight in when the door is PROPERLY CLOSED...
(light should go OUT).
ELSE your door switch "thinks" your door is open =
BROKEN or DEFECTIVE DOOR SWITCH
ServiceBench
As much as I detest SEARS... KITCHENAID is close behind:
If you cannot find your door switch issue on a REPUTABLE PARTS SITE
SEARS does have some "COMPETENT EXPECTATIONS"
for their repair service... Act quickly... SEARs is deservedly going out of business.
But first look around... for GOOD VIDEOS
(NOT YOUTUBE)
appliancepartspros, ereplacemntparts, partsselect.com
My KGRS807SSS00 Model Overview from PartSelect com
Search Over 2 1 Million Appliance Parts
Jan 23, 2017 | KitchenAid Kitchen Ranges
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
Lights Out and Door Open Indicator Flashes
The problem is above the doors at the switch, the unit can't see the switch opening (closing the door opens the switch). The linkage is where the problem is, the light go out to protect the fridge from getting too warm and the lights are remaining on after you close the door.
I hope this helped. Good Luck
Dec 22, 2013 | KitchenAid Refrigerators
I see moisture between the glass panels of the door.
Hello roderick234 - From what you have described it sounds like the beverage center has a poor door seal. When cold air and warm air outside is entering it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit.
Nov 10, 2012 | Electrolux 6.0 Cu. Ft. Beverage Center -...
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
Maytag Neptune washer (mah3000aww) won't start
IT IS THE DOOR AND SPIN SWITCH AT THE TOP OF THE DOOR IN THE CENTER THERE IS A KIT THAT REPLACES BOTH SWITCHES AND LOCK . IF THEY ARE BLOWN IT MAY HAVE CAUSED THE CONTROL BOARD TO BLOW A RESISTOR .TO CHECK THIS TAKE THE SCREWS OUT OF THE TOP OF THE PANEL OPEN IT AND INSPECT THE CONTROL BOARD AT THE RIGHT CENTER OF THE CONSOLE. LOOK FOR A BURNED OUT RESISTOR JUST OVER THE BOTTOM LEFT PROCESSOR YOU SHOULD SEE IT CLEARLY IF IT IS BURNED OUT IF SO YOU MUST ALLSO REPLACE THAT .IF YOU DONT THE NEW SWITCH KIT WILL BURN IT OUT ALLSO ...
Apr 25, 2017 | Washing Machines
I have a Frigidaire Beverage Center Model FFBC46F5LS It was installed on Friday and worked fine until today (Sunday) where it has started to beep constantly. If I press the light button at the bottom of...
Nov 14, 2010 | Frigidaire FFBC46F5LS
Interior lights stay on after car shuts off, doors and trunk are closed and dimmer switch is off.
there is a timer to turn the dome lights off,it could be faulty or each of the doors have a little black button in the door frame,you can pull the center of the push button out about a 1/16th of an inch,and close the door slowly to reset them.
Nov 28, 2009 | 1997 Jeep Grand Cherokee
Short in freezer?
IF THE WIRES SHORTED, AND THE DOOR WAS REPLACED,
WAS IT COMPLETE OR WAS THE DISPENSER ASSEMBLY TRANSFERRED TO THE NEW DOOR? IF THE ASSEMBLY ISN'T NEW, THE CONTROL BOARD IN THE ASSEMBLY MAY HAVE BEEN DAMAGED FROM THE WIRE SHORT.
Feb 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Architect® Series II KBCS24RS Beverage Cooler Logo
170 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
