Question about Zebra Office Equipment & Supplies
Setting up a new Zebra TLP2844z, and the left margin is getting cut off. How do I adjust it? Also, it's set for direct thermal, but it thinks there's a ribbon, can I disable it? Thanks!
    Problem Solver:
  • 7 Answers
Just go to your printer Propertie: in General\Printing Preference\Paper Size and Custom the size.
And change Paper left Margin
Posted on Oct 06, 2009
Please can you say me how to set correct margin size for Printer Zebra Xiiii plus
choose the "View > View Options" Menu with the BT document open and now enable the "Show Unprintable Region" checkbox. Will you now see the unprintable width margins covering part of the left margin of your label? If yes, then this means that due to the unprintable width of the printer you cannot print on this are (this the related to the printers print head tolerance).
With regards to the not being able to print on the bottom side, this could be a page setup issue. Please attach your BT document to this forum topic by using the "More Reply Options" button.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Techsupport Printer
Feb 26, 2014 | Zebra Xi Series 140Xi4 - label printer -...
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
My printer s4m is printing one side of the label the alignment is far right on the label
Check the size of the label that you are using if you are using label design software. If you are using another software, check your left margin setting. Hope this helps!
Aug 18, 2011 | Zebra S4M Thermal Label Printer
Labels are "faded" looking when printed. looks like you need to change ink but obviously there is no ink
Is this unit in thermal transfer or thermal direct mode? Depending upon the usage of this machine, perhaps a new thermal head is required. If thermal direct, try a different roll of labels, it is possible to get a bad batch. In thermal transfer mode, the tape could be bad as well. Try a new one to test.
Let us know what you find.
Thanks,
Dan
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
I cant seem to get rid of the "Ribbon In" error on my zebra S4M
1st change the print method to direct thermal on the LCD panel,  then check the driver on your computer, make sure you are printing with direct thermal
u can check the driver at printer & faxes , right click the printer and select printing preference .
Feb 11, 2010 | Zebra Z4M Printer
My zm400 keeps reverting back to direct thermal
did it stay on direct thermal if you not doing any print job ?
then i assume you the problem is when you printing .In ZEBRA DESIGNER, there's a printing preference that can be set up... i think u selected direct thermal when you print with zebra designer, that's why whenever u start printing, it show RIBBON IN again.
the solution is, Just changed the printing method from zebra designer.
if you aren't using zebra designer, then the problem at your driver. Open Printer & Faxes, then right click your Printer and klik on Printing Preferenced. There u can set up the printing method to Thermal Transfer.
The thing is....... changing the Setting from LCD panel won't change the setting on the driver.
i hope this will help you
Aug 19, 2009 | Zebra 203DPI Printer
Zebra S4M - Print quality problems - not keeping Thermal Transfer
If you are using a windows printer driver then perhaps you have "Direct Thermal" selected in the printer preferences. The driver setting will override anything you have set in the printer. So every time you send a new print job the settings get changed to what they are in the driver.
Jun 18, 2009 | Zebra S4M Thermal Label Printer
Zebra TLP 2844-z green/red light flashing
Check their website. It should let you download the user's manual after you've logged in.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844z.4.tabs.html
I work with these at my work-work, and the manuals are pretty handy to have!
Jun 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
421 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
