My copier says Paten is open closet paten. but everything is closed. what do I do?
    Guru:
  • 389 Answers
Each lid has its sensor. Usually this salients on lid, you it is necessary attentively to look, what salient overlays the sensor salient on lid, can be comes short quite little, arouse to press the lids by turns.
Unless it is got, follows to apply to service, sensors mortality, is violated contact to sensor, the sensor has forfeited its place.
Posted on Oct 08, 2009
After refill my cartridge firstly it shows cartride is not properly installed.After that when we give print command it shows service error 5010. my printer is pixma mp 140.
Error 5010 Possible solution. I did this and it worked but I do not know if the solution is related to the printer's error code. 1. Unplug printer....wait 30 seconds then plug it in. Make sure the unlock symbol is on unlocked. you can find this when you lift up the heavy top cover to see the paten. 2. Reset. Turn off. Turn on. Reset 3. If this does not work. Look inside close to where the paper comes out (from the front.) There is a little door that can be flipped up or down. Flip this door up. Repeat steps 1 and 2.
Jan 19, 2011 | Canon PIXMA® MP460 All-In-One InkJet...
Bisa ga nada tanda pesan masuknya lebih panjang durasinya???
gak bisa.... karna itu udah paten dari pabriknya......
Dec 24, 2010 | LG GD510 Cell Phone
Need handles for vintage Presto pots. Handles measue 4", with screws being at 3-/8 - 3-1/4" centers. Where can I find them?
We bought a set pf pan about 40 years age and th handles have broken,look for new ones.
the paten # is 2502495.
ther are 18-8 stainles copper botom.
e-mail is csjslmr@juno.com
Nov 28, 2010 | Presto 06821 Electric Skillet
I have a Wheelwriter from 1986 and the paten has a big **** in the roller from one end to the other. Is there any repair for this?
The platen is easily replaced. We can sell you one for 35.00 plus shipping but we must know the length of the black roll they are not all the same.
DickyO
Aug 08, 2010 | Lexmark Wheelwriter 5 Series II Typewriter
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
platen glass means that you need to clean the copy glass - glass where you put the originals for copying.
If you have an auto document cleaner there is also small glass on left side of "platen glass" wich is seen when you open the copy machine cover or dadf.
The black line is probably from dirt on copy glass, I pressume because courectour liquid ( most common ). use some stronger detergent or wd-40 to disolve the dirt and clean with glass detergent and dry it.
If you still have the black line try to print something from machine.If you do not have it on print its the copy glass problem - clean it - again.
Pls.rate
May 09, 2010 | Canon imageRUNNER 1023iF Black and White...
paten glass is the copy board glass.try cleaning both side,if still same.it can be off in additional funtion [copy board glass sign.turn it to off ]
Mar 17, 2010 | Canon imageRUNNER 1023iF Black and White...
We have a red line thru our scans? I have cleaned everything it says to clean?
red line? this is a black & white
is the line apear only when you scan ?
try and make a copy of the glass if you do not see line .than you problem is that **** glass that scanner uses.IT MAY HAVE WHITE OUT OR INK CLEAN IT .it long thin along the the paten glass
hope that help
Nov 13, 2009 | Kyocera Copystar CS-1820 Black and White...
Paper not advance
THE ROLLERS MAYBE DRYED OUT AND THEY NEED TO BE RECONDITIONED, OR NEW RUBBER PUT ON THE ROLLERS.
THERE IS A WAY TO TURN THEM DOWN YOUR SELF BUT YOU COULD ALSO MESS THE EVENINGNESS OF THE ROLLER, A SHOP THAT WORKS ON PRINTING PRESSES MAYBE ABLE TO HELP YOU OR IBM SERVICE CENTER MAY HAVE SOME OTHER IDEAS OR DO THEY EVEN MAKE PARTS FOR THAT PEACE OF EQUIPMENT.
ROD
Apr 16, 2009 | IBM 6400 Matrix Printer
EPSON LQ 1150 Roman letter two last two Can not print in foxpro
best way to come out of this problem is to fire your printing using an batch file
ex.
set print to scrn.txt
set prin on
? 'hello'
? 'welcome to fast printing'
set prin off
set prin to
run fastprin
create fastprin.bat file
edit fastprin.bat
@echo off
type scrn.txt >PRN
then execute the above program
Mar 04, 2009 | Epson LQ1170 Matrix Printer
37 people viewed this question
k24674
jasbo
jasbo
