Question about NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair
Have flat tire with hole in it. can it be fixed
Have flat tire with small hole in it. can it be fixed and if so what is required?
  • 945 Answers
Yes it can be fixed.With mine the dealer came and just took that wheel off and he asked the local garage to fit a new tyre on the rim.Then returned about a hour later and refitted it. hope it helps
Posted on Oct 15, 2009
Will fix a flat mess up the tire sensor
please just go buy a Safety Seal Kit and plug it.
That Fix a flat stuff will cost you a bundle when you need new tires.
Jan 08, 2014 | 2012 Ford Escape
Tip
Tube sealants keep bikes from getting flats!
When it comes to fixing and preventing flat tires on bikes there are many options from tire liners to puncture proof tires, but I have found that tube sealants have been the best solution. Tube sealants can be used to fix existing punctures in your tires and can work as a preventative measure against future punctures. Making them a great fix and first line of defense!<br><br>They're also super easy to apply, you just inject the sealant into the tire through the air valve on the tire. The sealant works to coat the inside of the tube protecting you from any future punctures and if there is a hole in your tire it will fill and seal off the hole. A simple solution for a very big problem!
on Aug 26, 2013 | Adhesives, Coatings & Sealants
Tip
Flat tires
If you have a flat tire before you go to the trouble of taking the tire off the vehicle buy and keep a tire repair kit for tubless tires. If you get a flat, jack up vehicle and find problem with tire. Ninety percent of the time it is a nail in the tire. With tire still on the vehicle pull out nail and follow instructions to put patch in. ( ex. pull nail out. put glue on tool supplied. place in hole. put patch on tool and dunk in glue. Insert patch into hole and twist to insert patch. Cut off excess patch. Your done. Inflate tire. ) This saves you time and money and is as good a fix as you will get at a garage. Good Luck
on Dec 11, 2009 | Ford F-150 Cars & Trucks
I have a 1993 Lumina Van that has a flat tire. I don't know how to get the spare tire down from under the car. I don't have anything that looks like a wrench
where your jack and lug wrench is located.. you should also have a long rod that is part of the jack assembly .. on your rear bumper look for a small hole. the rod gets inserted into that small hole and you turn left continuosly and the tire will start to drop slowly from the undercarriage of the vehicle.
Aug 05, 2011 | 1990 Chevrolet Lumina APV
Need repair sequence for flat front tire on DLS 3500 Craftmans Riding lawnmower. Actually, just need to remove it and I will take to local tire repair shop for repair.
Go to your local auto parts store, purchase a tire plug kit, leave the tire on the machine, plug the tire per instructions (personnel at the auto store will explain the use of the kit to you) and pump up the tire.
When you are done, put the tire repair kit in your car.
These things are lifesavers, every car should have one.
Once you have done a few flats, you can do them with air still in the tire in about a minute.
Good luck, Gary
Jul 10, 2011 | Garden
Put a new top belt wont start we found a small soring but dont no where it goes went and started ok before belt went on . when turn key is like flat battery but had on charger not that help please
Hi
The belt goes on the top of the variable pulley and the transaxel pulley. There is a belt tentioner (flat Pulley) You need to remove the pulley and look on the bracket side closest to the clutch/break petal for a small hole for the spring. Put the spring hook in the hole through the top of the bracket, let it hang. Replace the pulley. Now remove the rear tire and rim on the left side of the mower. Clutch/ break is the left side. If you look where the tire use to be toward the front you will see the hole where the other end of the spring goes. The flat pulley goes toward the flat side of the belt.Pull the spring with a vice grip place the other hook in the hole.
Hope this helps
Terry
Jan 15, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My jeep jogging stroller has a flat. Do I need to
Replacement tube may be more beneficial even though the fix/patch may be cheaper. If you live in an area that have varying climate, the patch along with the repaired tube can expand and contract and may cause small leak if not repaired properly.
Otherwise I would get the right size tube, most jogging strollers are either 12" or 16" tube inside and can be bought from your local bicycle store. With that, you'll need bicycle tire levers which can also be bought at the bike shop. Just about any type of tire levers will do. Of course I'm sure your bike shop can do this for you to possibly for free with a purchase of replacement tube!
Oct 27, 2009 | Jeep Liberty Limited XT Urban Earth Jogger
What does low trac mean?
Sound's like you have a bad tire. There are steel belt's in the tire that help keep there shap, but when one belt's break you have flat spot that make's it seam like your driving over pot holes. Before you go off changing the tire have it balanced first to see if that is the real problem. Good luck.
Mar 25, 2009 | 2000 Pontiac Grand Am GT
How to repair a flat tire?
hi!
to find the hole, try to fill the tire with air, and put it on a shallow water were it's enough for you to see the bumbles that come out from the tire.
to repair a flat tire, take out the interior of tire and if you happen to see the location of the hole try to find an unused rubber and cover the hole with that rubber and glue it with a quick drying glue... (this is a non-professional work)
Oct 29, 2008 | Bell Sports #1002016 26" Mountain Bike...
Fixing a flat tire
Any bike shop will have patch equipment. You need to deflate the tire and remove it from the wheel. See if there is a tube inside the tire. If so, the fix is easy: either purchase a new tube for the tire, or get a patch. Use modelling glue on the patch then press it continually on the hole on the tire for about five minutes until it is dry. Afterwards, re-insert the tube into the tire, reattach the tire to the rim and pump it back up
Jul 13, 2007 | Kolcraft Jeep Liberty Limited Urban...
NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair Logo
172 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
