Panasonic KX-TA824PK 1 KX-TA824 unit plus 3 KX-T7731-B Phone
Problem for Panasonic KX-TA824PK 1 KX-TA824 unit plus 3 KX-T7731-B...
How do I forward calls to an outside number
By domalley142 on Oct 06, 2009
How do I forward calls to an outside number on a panasonic kx-ta824 system. what is the line access code
Comments:
Oct 09, 2009
- I currently do not have access codes programmed. do i need to enable in order for forwarding to work?
Oct 10, 2009
- I tried your suggestion and the system picks line 6 which is not active. I have 4 lines on 1-4. should i just move the lines to 3-6
Oct 12, 2009
- Thanks. disabling the inactive lines did the trick.
Best Solution
posted on Oct 08, 2009
Very Helpful)
cnavarro
Rank: Guru  Panasonic Phones & Accessories  Expert
Rating: 90%, 592 votes
Line access codes are the codes you dial from the intercom to get an outside line. 9 works.
Call forwarding to an outside line has to be enabled in system programming either 2.1 in the maintenance console or option 607 in system programming. There's also a timer that allows the CO connection to be maintaned. By default it's 10 minutes.
Once you get the program set up, you can dial 7139xxx-xxx-xxxx#
Carl
Comments:
Oct 09, 2009
- You don't program access codes, they are there by default. Go to a system phone, press INTERCOM and dial "9".
Access code. By default on an 824 it picks main trunk group high to low, On a 624 it picks in a sequence that you set in programming or low to high.
Oct 10, 2009
- Oops, try disabling lines in system programming 3.3 or or option 400. It makes it tons easier.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Replies have been very useful and informative. " - domalley142
Popular Solutions for Panasonic KX-TA824PK 1
Questions and Unsolved Problems for Panasonic KX-TA824PK 1
Do you recommend Panasonic KX-TA824PK 1 KX-TA824 unit plus 3 KX-T7731-B Phone (KXTA824PK)?
Answer
Answer
i get cannot open usb port using code 1234 at system programming location even after resetting... (More)
Answer
Greetings, I've got an message from the Panasonic KX-TA824 pbx central phone system: the system... (More)
Answer
Dear I have configure my pbx model liste above, but it happen that if an internal is call, if... (More)
Answer
When using the FWD/DND button our KX-TA7731 or 7736 it asks for an ACCNT Code. We don't want to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic KX-TA824PK 1...:
Top Phone Experts
Rank: Guru Guru
Solutions: 567
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Phone Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
