Question about LG DLP Projector 1400Lum RD-JT30 Multimedia Projector
TV won't come on
I am having a problem. My tv wont' come on. it warms up but when it gets to the lamp light it only flashes red. What does that mean?
  • mst518 May 08, 2008
    according to the owner's manual, this means the projector lamp needs to be replaced. i have the same problem. called extended service contract people, they sent new lamp ($200/lamp!!) and say the owner can replace it. instructions came with bulb. but not accurate - it's not how MY tv looks. so now waiting for service technician to come replace bulb....called LG back and they said owner should definately NOT replace bulb - needs to be done by service technician. i love the tv when it works. but do not like the maintenance costs! won't buy another and wondering how to get rid of this one! apparently this is a common problem with DLPs....hmmm, don't know how to post this....tried before....maybe it'll pop up twice??
According to the owner's guide, this means the projector lamp needs to be replaced. i called extended service contract people and they are sending new bulb, with instructions for changing. however, the instructions are NOT accurate. now waiting for service technician. bulbs cost $200!! apparently a common problem with DLPs. i love this tv when it works, but do not like the high maintenance cost i'm discovering. would like to get rid of it, but don't know how!
Posted on May 08, 2008
The power pack of the tv is faulty.check the power pack.it is devided into the standby mode and the main power mode;an ic (POWER IC ) IS RESPONSIBLE IN THE POWER PACK .
Posted on Feb 26, 2008
Wont power on
Sounds like you need a new bulb, or possibly new lamp. The red/green flashing is the warm up to get the bulb ready. If it's shutting down after that, instead of turning on, it means the bulb isn't working - that's a common thing, for the bulb to burn out. Possibly the lamp's bad, but that's much less likely.
Sep 01, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Problem with Sony Grand WEGA KF50WE610 50 in. Rear Projection HDTV-Ready Television. Does this indicate that the lamp is burned out?
if the lamp indicator is blinking and won't turn on which means you will need to replace the lamp.if you don't have an idea how to replace just leave it to the tv technician to fix your tv.
Sep 17, 2012 | Televison & Video
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Hi, We have a Toshiba rear projection tv model 46WH08G which wont turn on. by this we mean that the red power led light is on and weve noticed that the green led light alongside is flashing, which has a...
It sounds you need a new Projection Lamp; they usually last for 2000 hours or more. The led blinking is the lamp warm-up period and it fails now, if you replace the lamp be careful very static sensitive and blow the dust out with air while the TV is open. Hope this Helps.
Apr 08, 2010 | Televison & Video
Standy Light Flashes 6 times when I turn the TV on.
First thing I would try is the micro switch on the lamp door. The doors get overheated and warp pushing away from the switch. The micro switch shows the tv an open door and wont let the tv start. Depending on the model you have the lights mean different things but on a WEGA rear projection LCD it ususaly means a board has failed. I just had this problem on a KDF-60XBR950. The C2 digital board was bad. Good luck
Jul 31, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
228 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
J.D. Browning
J.D. Browning
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
