i have had the thermostate tested at a local shop and they say its ok. while the machine is running i have checked that the heater is getting power which it is,i also checked to see if there was power going through the elements this is also getting power but it is not heating up.
many thanks
In order for a drier to work it requires cold air to blow from a fan onto an element, The element in turn is supplied a voltage via the timer, this inturn is regulated via a thermostat, and or cut out , if all the conditions are correct the drier will work.hope this is of some help to you....
tumble dryer door catch not working. ive unscrewed the catch and removed it but im not sure where...
(More)
tumble dryer door catch not working. ive unscrewed the catch and removed it but im not sure where the metal curve piece is supposed to sit ?
when switching on the dryer it does not spin just same sound as if the cycle has finished.i have...
(More)
when switching on the dryer it does not spin just same sound as if the cycle has finished.i have opened top of dryer and switched on and the on light goes on and off.wondered whether it was relay circuit whether it has burnt out.
my water full light comes on after a short period and stops machine leave for 30 mins or so and it...
(More)
MY WATER FULL LIGHT COMES ON AFTER A SHORT PERIOD AND STOPS MACHINE LEAVE FOR 30 MINS OR SO AND IT GOES AGAIN FOR ANOTHER SHORT TIME
