My washer lets in water, empties and the drum goes round when doing so but it will not spin. The wash enhance button and the on/off button are both constantly flashing when it gets to spin on any cycle. I have changed the load thinking it may be uneven but to no avail.
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Could be a water blockage, Try cleaning the filter
Posted on Oct 06, 2009
My washer wont spin,
If you had to empty the water manually, i.e the outlet pump did not drain the water out then I would suggest the pump is either blocked or has failed. This will normally prevent the spin cycle from occurring. Try checking and cleaning the pump filter out.
Dec 31, 2013 | Frigidaire ATF6000ES Front Load Washer
The washer will not drain. It goes through all the cycles, fills with water, washes, but when it gets to any of the spin cycles, it stops. The hose going to the drain is NOT clogged.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 04, 2011 | Whirlpool LSR6232J Top Load Washer
Wont go into spin cycle
will the drum go round when on a wash. and is it drianing water out if the drum goes round its not your brushes. if it not emptying water you pump as gone and will not spin if there is water in the drum
Jun 28, 2009 | Kenmore Washing Machines
Changed brushes still wont fast spin and empty water
Let me ask you who told you to change the brushes... Im curious!
Jun 10, 2009 | Washing Machines
Hotpoint washing machine
INSPECT THE BELT MAKTYBE BROKEN OR CAME OFF ??????????LET ME KNOW
Nov 29, 2008 | Samsung WF337AA Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
Zanussi washing machine
Filter can be clogged, pump can be dead or water outlet clogged.
Apr 11, 2008 | Zanussi ZWF1430W Front Load Washer
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
