Question about Sharp LC-26D6U 26 in. LCD Television
Wats the part no.for the a/v card (sharp lc 26d6u) ? getting no sound.i think this is the problem..
  • 16 Answers
The A / V board part number is: XD352WJ
If you want to try and repair this yourself, you most probably do not have to replace the board. See the following:
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a 2502 Heat Kit is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from partstore.com for $19.95. However, it is entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95, also from partstore.com. Please note that board replacement for this problem is almost never necessary, so if you are working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with electronics disassembly/reassembly and is willing to take things slowly, this can even be a DIY project. One can find important service references by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat buried under other boards. Please also refer to post # 373 at: avsforum.com/avs-vb/showthread.php?t=647174&page=13 for some pics of the information detailed here.
My knowledge of how to solve this issue came primarily from finding the research efforts of Aureius on the AVS forums, and particularly from his taking the time to post the solution publicly so that others might save time, money, and aggravation. I am just passing along the information. Thanks Andy!
I also wanted to mention that a couple of other very pesky common problems with these series of Sharp TVs involving symptoms of random powering-off and/or powering-on, and function lock-ups of various sorts are easily remedied through two firmware updates (Main CPU: PH1UU112, Monitor: MD1UA104). These are not available to end-users via the internet but it may be possible to get the files from an understanding factory-authorized repair tech. They are installed using an SD memory card (don't use the HC high capacity sort, use only those that are NOT HC) which is inserted into a special slot in the back of the machine. Again, for those of the DIY persuasion, information about how to check whether your TV has old firmware in need of an upgrade is readily available through internet search.
Posted on Oct 29, 2009
  • Gleg Assistance Oct 29, 2009
    It has recently come to my attention that Sharp is now willing to repair this common audio problem without charge even if the unit is out of warranty, due to the very high occurance rate. If one chooses to have the set repaired, I highly recommend instructing the technician to install both firmware updates outlined in the above solution, as this solves a myriad of various other pesky problems.
    Problem Solver:
  • 9 Answers
You don't even have to worry about what the part number for this issue. Sharp is taking care of this for customers even if you are out of warranty due to a mistake on how they made the tv. All you have to do is call Sharp at 1-800-237-4277. It took my repair in NYC (MTZ electronics) shop 1 day to fix the issue. MTZ electronics even applied 2 firmware updates that all the D6U tv's need to avoid other known issues with the lcd in the future. These firmware updates are for the main cpu PH1UU112 and the monitor MD1UA104. I am so happy and am loyal to Sharp for their fantastic customer service. I also want to thank MTZ electronics for having the best customer service and being the best repair shop I have ever been to. Good luck everyone
Posted on Oct 07, 2009
I am missing the 4 screws that secure my TV to the stand and needed to know what size screws to buy. The TV is a Sharp LC-26D6U (old TV). Any ideas? Thanks.
They probably are metric M8 but the length is critical. Too short won't hold and too long may interfere with circuitry underneath.
Feb 14, 2017 | Sharp LC-26D6U 26 in. LCD Television
Sharp LC-26D6U turns on to a blue screen
Your set need a though check up. It sounds that the main digital board has damaged. Before make it sure, contact any service technician and make it confirm. A panel fault too can cause this. If you wish to get more details about this kind of fault, check this link. http://electronicshelponline.blogspot.com/ If you're sound in electronics, you can follow the rest. Pull up older posts there, either by its left side bar, or, see it in 'Timeslide' option.
Jun 22, 2013 | Sharp LC-26D6U 26 in. LCD Television
My sharp lc-26d6u aquos got picture but no sound, anything i can do? thanks!
No sound on ALL MODES?
Let verify first to narrow down to where the problem can be. First, make sure the MUTE or SAP function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit.
Please post back what you find.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 26, 2011 | Sharp LC-26D6U 26 in. LCD Television
The tv turns on with sound but the screen is just white
Ur tv Tuner board is dead.Replaced the Tuner board,u will get ur incomming cable or free air tv signal go through and get ur tv picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
May 05, 2010 | Sharp LC-26D6U 26 in. LCD Television
My Sharp LC-26D6U TV - low audio
Sharp is taking care of this for customers even if you are out of warranty due to a mistake on how they made the tv. All you have to do is call Sharp at 1-800-237-4277. Please make sure that the repair shop also applies 2 firmware updates that all the D6U tv's need to avoid other known issues with the lcd in the future. These firmware updates are for the main cpu PH1UU112 and the monitor MD1UA104. Good luck!
Sep 28, 2009 | Sharp LC-26D6U 26 in. LCD Television
No sound at all!
I agree with everything that they are saying.
Most tv companies under design the cooling needs of the flat panel TVs. I had to fix a few TVs this way that had similar problems. Mostly with the picture on TVs freezing up because of the poor cooling design for the motherboard processor. I would give their solution a try before replacing circuit boards.
Jun 10, 2009 | Sharp LC-26D6U 26 in. LCD Television
Lc-46d43u aquos lcd tv
The remote code 31 worked on my Motorola cable box.
The REmote is for a Sharp LC-32GP1U
The code was listed under one of many for Jerold. I entered codes one by one testing the secondary power button each time.
Code 31 works fine.
Oct 28, 2008 | Sharp LC-26D6U 26 in. LCD Television
The sound just quit
check your speakers & your sound board
Jul 07, 2008 | Sharp LC-26D6U 26 in. LCD Television
Sharp LC-26D6U sound issues
Capacitor is what I found out.. (Supposedly althoug Ive not verified).. If you can send here I'd love to see the unit...
(Theres a reason)....
Ken
Dec 27, 2007 | Sharp LC-26D6U 26 in. LCD Television
Sharp LC-26D6U 26 in. LCD Television Logo
309 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
