Question about Delphi Roady XT XM Radio Receiver
My delphi roady plays through cassette adaptor. Volume is very low even when audio level is moved all the way up. ???
You need to cycle back through after puttung the cassette in. Mine did that (before the cassette feature stopped working altogether) and I would press my "source" button so it would go from the cassette to the radio, then CD and back to the cassette - the sound would be back to normal again.
Posted on Oct 18, 2009
Will delphi sa10000 without cassette player
Should be able to hear Sirius channels through your FM radio. Cassette is better, but you can just set up your FM radio to the same channel as you set the Delphi unit. See instruction manual (download from online here) http://www.siriusretail.com/pdf/hardware_support/delphi/skyfi_operations.pdf
Jun 01, 2014 | Delphi SKYFi SA10000 XM Radio Receiver
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
What do I need to install my roady to a 12volt dc system?
Just a Delphi 12VDC cigarette lighter adapter plug that will plug into this unit. You will also need an XM mini car antenna plugged into it. This has a nice FM transmtter, so you can use that, or use the audio output plug to go to your car AUX input jack or use a cassette adapter. Okay? More questions, just ask.
Apr 18, 2010 | Delphi Roady SA10035 XM Radio Receiver
Trying to install Roady 2
If the Roady2 has a fm modulator built in, you can go to the menu and set the fm frequency. If it doesn't, you could use a fm transmitter that they have for mp3 players to listen to in the car
Apr 13, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Mar 01, 2008 | Delphi Roady XT XM Radio Receiver
Xm radio
mine does the same thing.
Nov 03, 2007 | Delphi Roady XT XM Radio Receiver
A/C Adapter Noise and Interference
I just got my radio and home kit today, the hi pitched noise is awful so I looked online and found you.  I finally hooked the car adapter into a wall plug adapter and volla- NO NOISE!  Whew. It's a $9 adapter I got for my ipod car adapter....just has a hole to plug in the car adapter and you plug it into the wall.
...good luck
Feb 24, 2007 | Delphi Roady XT XM Radio Receiver
Noise with casette adaptor
Well Jill the problem you are having is called inducted noise. The lighter power adapter cord is inducting electrical current to the cord used by the cassette adapter thus creating the the noise you've been hearing. Do your best to separate the two cables as much as possible. I realize that your unit may have both cords coming out of th same side, and that's fine. the longer the run of wire, the easier it is to have induction issues. If the cords do come out on the same side, run one up and the other down away from the other cord. Do not coil the lighter adapter or cord either, it increases the chance of being able to induct noise. If your unit is to close to the lighter assembly you may need to move the unit to another location in the vehicle itself to help combat the noise issue. Other options include to shield the cassette adapter wire, i use aluminum tape for heating/ac ducts. The only other option i can see is purchasing a FM modulator which will transmit the units sound wireless-ly through an FM radio channel. You will want to check and see...i do believe most XM radios have a FM modulator built in. Hope this helps, and good luck.
Oct 03, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
99 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
