Question about TechnoMarine Watches
I have a technomarine chronograph tmy22..it needs a new stem how do get this repaired?
5 Suggested Answers
SOURCE: technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
Posted on Sep 29, 2008
escapement
  • 2334 Answers
SOURCE: hi i have a citizen 100m chronograph watch and i
You have to take it to your nearest Citizen dealer, as you won't be able to replace stem yourself. Note: You do not need to remove or to do anything with the stem for replacing battery.
Posted on Jan 25, 2010
escapement
  • 2334 Answers
SOURCE: brand new technomarine watch chronograph csx wont
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
Posted on Nov 06, 2010
  • 6771 Answers
SOURCE: just bought a technomarine watch
Sometimes the crown is screwed in to help keep it water tight. Turn the stem anti-clockwise to see if it will release "give several turns" if that fails return it for exchange.
Posted on Dec 31, 2010
I was just given a black RSX 05 TechnoMarine chronograph watch, but the date is wrong. I can't seem to figure out how to fix it and I wasn't given an instruction book. How can I change the date?
your watch crown has 3 position. the normal position, the second position and the third position. pull it to the second position then turn it counter clockwise or vice versa. then push it to normal position if your done. i hope i had helped you..
Jul 10, 2011 | TechnoMarine Raft RSX05 Unisex Watch
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
Just bought a technomarine watch and can't pull out stem to set time and date
Dec 31, 2010 | TechnoMarine CSX01 Wrist Watch
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
Nov 05, 2010 | TechnoMarine Cruise Watch
The stem broke off of carrera watch. How much should repair for this problem be?
mcdevito75 here, A new stem and crown Approx. for your Tag Heuer, $125.00 that"s if the stem is broken, if the stem just pulled out it may be able to be saved. Check here at fixya, bottom of page, click on repair service directory the watches.
Jul 03, 2010 | Tag Heuer Automatic Chronograph Series...
I've lost the chronograph button above the winder. Where can I buy one on line and does it screw back in. Thanks. Edmond
mcdevito75, Best Bet with your Chrono watch is, check out a small watch repair shop in your area for that btton and replacement. A smaller watch repair shop may save you some money on costs.
Jun 22, 2010 | TechnoMarine Ceramique Watch TCB02C
Hi i have a citizen 100m chronograph watch and i have broken the stem trying to replace the battey how do i repair it or do i have to take it to be repaired.thanks karen
Jan 24, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
How to change the hour
on most watches, you can change the hour by twisting the crown... As I can see this is a chronograph watch, mostly divers use these kinds of watches. the two other buttons are to set the chronograph. As i do not know what brand this is but, try to play with it you will find out. Or take it to a watch professional.
Jul 30, 2009 | TechnoMarine Dial Chronograph Watch
Technomarine watch battery replacement
Sep 27, 2008 | TechnoMarine Apnea 35mm Watch - Silver...
Watches Logo
49 people viewed this question
Top TechnoMarine Watches Experts
Ansel Alberto
Ansel Alberto
Stan Ford
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
