Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Hi, i have cold tumbler on my wt945S - Frigidaire FEX831CS Top Load Stacked Washer/Dryer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 8 Answers
Can you suggest me the name of any best quality tumbler?
Quality tumbler are the one which will help you to keep your beverages as it is without the effect of temperature. I always prefer to use Yeti tumbler because this tumblers keeps ice 2X longer than plastic tumblers and are designed for maximum ice retention - and work just as well for hot beverages.It had a double-wall vacuum insulation which will keep beverages cold or piping hot longer. This tumbler have a Dimensions: 6 7/8 in high; lip diameter of 3 1/2 in. It is a BPA-free and have No Sweat Design to make sure your hands stay dry.
Sep 02, 2017 | Cars & Trucks
1996 mercedes lock cylinder housing removal
Hi Adrian, what is the model of you car.. is it a C-Class W202 or E-Class W210 model. If you can supply the Vin or chassis number.. starts with WDB.. and 14 digits after that. The steering lock is held in with pin, depending on model.. to remove key tumbler you need a special tool (which can be easily made in a w/shop) but still need the key to turn tumbler to position 2 to insert tools to remove the tumbler. Than remove the cover shroud that is over the tumbler. Than the steering lock can be removed, if you cannot remove the tumbler, the steering lock will have to be cut out in place.
May 17, 2014 | Vehicle Parts & Accessories
1998 expedition. The radio does not work at times when the vehicle is started. When this happens, the locks do not lock when vehicle is put in gear. After a period of time, the radio will come on, and the...
sounds like you have two separate problems locks and on a relay and it may be getting weak ready to go out . The radio sounds like a loose wire you need to remove the radio and see if any wires are loose there also might be bad contacts in key tumbler try to wiggle the key if you have more than three keys on your key ring that will cause stress on tumblers and can short out ignition .
Jan 13, 2014 | 1998 Ford Expedition
A friend gave us a Troy-Bilt tumbler composter, but it has not instructions with it. We just need to have instructions on the correct way to operate it.
Hi grammaj308...
Hi sorry I could not find your exact troybuilt tumbler composter
But if you wish, Go to this webpage and learn about compost tumbling.
http://www.spinning-composter.com/
Sep 01, 2011 | Vacuums
I removed the original ignition tumbler and ordered a new one from BMW and it should just pop right in but it will not lock in. Any advice or suggestions. Could it be a wrong part ( they look identical...
Hi Kevin,
If you removed the original tumbler check to make sure the alignment tab on the edge of the tumbler did not break off and stay in the housing. The tab is very small, about 1-2mm and the housing has a small indentation where the tab lines up, I also recommend making sure to use the removal tool or pin clip to install the replacement tumbler.
Aug 17, 2011 | 1997 BMW 328
Is there an easy online guide to changing out the ignition tumbler in a 1992 dodge caravan?
First remove the plastic 2 piece shroud around steering column so as to gain access to the housing the tumbler sits in. Find three Phillips screws to remove in holes in the lower piece.
Turn the ignition key to the Run position. Insert a small tip screwdriver in the access hole on the bottom of the housing to push the spring-loaded tab which will free the tumbler so you can simply pull the tumbler out with the key.
Installation is the reverse. Be sure tumbler with key inserted is set to the Run position.
Depress spring-loaded tab, insert tumbler into housing hole with tab down. All the way in,
Turn key to the Lock or turn it off.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 10, 2010 | 1992 Dodge Caravan
Non-power door locks do not open in cold weather. They have been lubed. As soon as it is cold, it is always a struggle to get in.
On locks and lock mechanisms, I always use TriFlo, it is a silicone and Teflon based spray, that won't get thick in freezing temps. before you use it clean what you have oiled with a nonflammable electric parts cleaner spray and allow to dry.
Oct 12, 2009 | 2004 Chevrolet Cavalier
Maytag Gas Dryer - Flame trips high limit Tstat
firstly..is venting blocked? disconnect venting and try it. if problem persists then replace hi limit. assuming what you just told me was correct.
Jun 11, 2009 | Dryers
Dryer takes a least two cycles to dry a load and just started making a strange noise.
hi,if you belt runs blower and tumbler,it could be lose belt,or worn out. the blower creates draft in dryer,and tumbler to fluff up. if the speed of tumbler or blower is not rite it will take long time to dry.and the nosie is the belt sliping.
May 29, 2009 | Dryers
My kenmore 417.94812301 staked washer / dryer problem
Your dryer was made by Frigidaire and needs what is called a rear bearing kit (#5303281153 costs about $30) from frigidaire.
there is also a good chance that your bearing failed because the dryer overheated (overheating is mostly caused by the venting being restricted)
Oct 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
103 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
