Question about Lavazza Espresso Point Capsule Machine
Loud and Slow! 3+ minutes to make a cup of coffee.
The machine makes a TON of noise and takes a loooong time before the water starts flowing. Often we have to press the button more than once to fill the cup. It is taking 3 + minutes to make a cup of coffee. The steamer arm no longer works either.
    Problem Solver:
  • 19 Answers
Needs a pump and a valve contact me at www.lavazzarepair.com
Posted on Oct 13, 2009
Why is my coffee weak?
If it is a drip maker, only gravity drives the hot water thru the coffee grinds. If the coffee is ground too fine, it immediately packs up and doesn't let water flow thru it and the water flows around the coffee instead of thru it.
Try using a coarser grind, and if not you can use a lot smaller amount of coffee and water. A smaller amount of coffee is easier to diffuse thru than a large amount.
Another thing is to slow down the water speed entering the coffee basket. I found the best way to do that is to use water just above freezing and place that extra cold water in the reservoir. The cold water takes extra time to be heated up by the coffee maker so less water is released over the coffee grinds per minute.
If your coffee maker overflows a lot, that is a good indicator that the grind is too fine and/or your coffee filters are too flimsy and are plugging up the channels in your coffee basket and the coffee can't enter the flask, so it overflows.
But the easiest way to check out your coffee maker is to use extra cold water and just run half batches (5 cup) of coffee instead of 10 cup
Feb 25, 2015 | Coffee Makers & Espresso Machines
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Gaggia titanium - between cups of coffee, we leave the machine on. After only a few minutes, the machine makes a loud clicking noise, and then the noise speeds up. A very loud, clicking noise, very...
Hi, That loud noise is the pump, pumping without water running through it. Thats not good. Will do expensive damage to whole machine if let go. It needs flowing water to stay operating for a good life. Already sounds like an ECU board. It may only be trying to rinse itself, but is cloged, and cant get enough water into it. It needs to be looked at by a repairer. I can helpyou there if you live on the sunshine coast. Dazza
Aug 21, 2011 | Gaggia Titanium Espresso Machine
My coffee maker takes 20 minutes to brew a pot of coffee- extremely slow- I've lost the manual and do not know how to correct this...please help.
The first suggestion is de-calcify as the heating element is probably coated. The following should explain what I mean.
Most likely you have calcium flake deposits clogging the orifice/jet/valve, that restricts the flow of water until heated properly. As the water starts to flow the flakes collect and block the water flow. Periodic cleaning will cure this and prevent damage to the, orifices, jets,valves and heating elements of your machine ( as calcium builds up it tends to insulate the heating element thus requiring more energy/heat to complete the task). Eventually the heating element will over heat and burn out. Periodic cleaning extends the life of the machine plus the added bonus of a better tasting " Cup of JOE".
Most any cleaning preparation designated for a "Mr. Coffee " type machine will do the job. If you want a home remedy 3-4 tablespoons of white distilled vinegar per cup of water ( calculate for the size of your water reservoir ). But please do it outside on the patio, as the vinegar tends to be in competition with the air freshener, and will win.
sincerely,
Doc Michael
Mar 08, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Keurig coffee maker makes loud noise single cup brewer. Make loud noise prior to brewing.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 20, 2010 | Keurig B60 Coffee Maker
Not brewing. Add water and coffee, switch to the brew selection and the water/coffee does not flow. The machine heat ups and starts processing noise.
Make sure the lid is on the carafe.
Make sure you are not using a paper filter and a gold tone filter at the same time.
Make sure the carafe lid is down all the way and that the center knob of the carafe lid is making contact with the spring at the bottom of the filter basket.
If the above conditions have been met, then decalcify your coffeemaker by running 1/3 carafe worth of vinegar and 2/3 carafe worth of water through your coffeemaker - use the self-clean button to do this - will take about 35 minutes.
Aug 30, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
First cup of the day ony fills half way
Have you cleaned the exit needle? Seem to be clogged up, more info here: http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
Nov 16, 2008 | Keurig B60 Coffee Maker
Long brewing time
Clean it out with 1/3 caraffe distilled white vinegar and 2/3 caraffe water. Once it is clean, it should take the normal amount of time and will make slightly less noise since it isn't busy steaming off as much water. Also, double-check the filter basket and make sure it is not slowing down the rate of draining coffee.
Mar 21, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Lavazza Espresso Point Capsule Machine Logo
246 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
