Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Wbr-2310 d-link I am trying to connect to my wireless network from my business computer from work. It is asking me for our wireless network password. I've forgot it. How do it find it?
  • 56 Answers
Follow these steps:
1.Type 192.168.1.1 in Internet Explorer.
2.You might have to put Admin password to access the router which is usually admin and password field blank.
3.Go to wireless setting and change the password.
Posted on Dec 25, 2007
Wbr-2310 driver
Routers don't use drivers. You PC connects to it through the network, either wirelessly or through a wire. If you need to configure it, you can visit
ftp://ftp10.dlink.com/pdfs/products/WBR-2310/WBR-2310_ds_ca.pdf
to view the datasheet.
If you plug the wires in (your incoming internet signal goes to the Internet jack, and any PC's connect with wires to the back of the unit) then that computer should be able to connect.
If you are connecting wireless devices to it, you will need to enable wireless networking.
To change your settings, you will need to log into the router by typing 192.168.0.1 in a web browser. A pop up will come up asking for a user name and password. Here is the default password, unless someone changed it.
User name: admin
password: (leave blank)
Once you are in you can adjust wireless settings, security (for a password-secured connection). A word of warning here: If you create a password make sure you copy it down exactly because you will need to enter it before you can connect to it.
Dec 22, 2011 | D-Link Computers & Internet
After cable co. split cable and installed another modem, D-Link WBR 2310 router no longer works with its original modem. Tried resetting, unplugging, etc. Can't get wireless.
Use an Ethernet cable to connect your computer to one of the LAN ports.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for a line of output like:
Default Gateway . . . . . . . . . : 123.468.32.1
Start Internet Explorer
Type http://123.468.32.1
Press Enter
Login to your router
Click to run the "Wireless Networking Setup Wizard", to:
1. set an SSID
2. set an encryption-level, e.g., 'WPA' or 'WPA2'
3. set a password for your network
Click OK to restart your computer
Use your wireless device to connect to that SSID, using that password that you set.]
Jun 06, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Wbr-2310 dlink router wired connection issue
connect your computer to the router by an ethernet cable. Open Internet explorer or FIREFOX. Type the roiuter's default IP-address (if not known: its either 192.168.0.1 or 192.168.1.1 or 192.168.0.0 or 192.168.1.0... keep trying until you're answered and asked for the password to enter the router (either attached on the router, in the manual or try: user: admin password: admin or password: password. Whgen you're in you'll find many checkboxes you could fill oput or notr; Easyway: give your net a name (SSID), then choose the network access security (set it to wpa-psk), choose a password and enable DHCP (then the router does the rest). Disconnect, look if the computer sjhows reception of your netwoirk by displaying its name. then connect. You will be asked for the password you chose. Done.
Jun 04, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
How can i made admin password in WBR 2310?
in your explorer bar
type 10.0.0.1
log on as ADMIN
Password Admin or 1234
add new user when logged on
create your password here
make new user the default user
'write down log on details and password too
open a second explorer bar and log in as new user for testing
if working save your settings and close explorer
open in admin mode then try new user mode
admin probably wont work now new user is the default user so everything should be working now
cheers Misterdj
Apr 18, 2010 | D-Link 802.11g Wireless Router WBR-1310...
WBR 2310 wireless stops working.
Please reset the router and also remove the network from the devices and reconnect with the password.
for more visit www.leadingpcfix.com
Feb 13, 2018 | D-Link RangeBooster G WBR-2310 Wireless...
I can't access manually my wbr-2310 (modem router dsl-500b)
you need to configure the wireless on the router through a cable connection at first. after logging in on the router (default admin login and password should be mentioned in the router's manual) you can enable the wireless and the DHCP. to access the router, open an internet browser window and surf to the address http://192.168.0.1, where you will be asked to fill in the admin password.
please keep us posted on any evolution
Jun 22, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
My PS3 is asking for a wpa key code so I can go online?
If you dont know your wpa network key try to reconfigure your wireless network again.
Access the configuration page of your router.
>Type on the address bar 192.168.0.1
>On login type Admin leave password blank. if you set up a password or the login page use that one.
>Once inside the Dlink Page
>Clik Setup and on the left side click wireless setting.
>If given the option to click on manaul wireless connection setup click on it.
>Once you have the wireles window
>try to change the network name to a new one and scroll down
>Under security choose WPA security (enhanced)
>Scroll down and under the Passphrase type in your new network password or security key and confirm it.
>Click on Save Settings
>If it asks you to reboot then reboot it, if not, its ok.
Jan 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Erreur 102
Clink start--got to--> RUN --> type in " NCPA.CPL " and press O.K.
- you can see the network connection window has "Local Area Connection" and "Wireless Network Connection" . Highlight the wireless connection and right click got to properties. now you can see properties window appears. Click Wireless Network Tab. you can see " Prefered Network" with the Add and remove button. If you see " erreur 102" under prefered network, then you can highlight it and press delete button.
- Click add button and search your actual wireless network name and add it.
Please feel free to ask, it you need any more assistance in this.,
- Laxman
Nov 18, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
317 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
