Question about Kenmore 43389 Electric Double Oven
What size breaker for the 43389 oven? - Kenmore 43389 Electric Double Oven
    President:
  • Kenmore Master
  • 1,922 Answers
40 amps per leg
Posted on Oct 06, 2009
What size circuit breaker is needed for a jenn-air wall oven 240 volt 3 wire #6wire model 800181
most ovens require a 30 amp circuit breaker ( now RCD unit)
talk with an electrician as to the requirement
Aug 17, 2016 | Jenn-Air Ovens
Hi,my belling model 664 wh is tripping out just as it reaches set temp on main oven dial,i have just replaced the main oven element, any solutions I would be grateful. Thank you.
Sounds like the amperage draw of the oven is right at the breaker size. Circuit Breakers should not be loaded more than 80%. Breakers take time to trip when they are close to the limit. IF the problem started with the replacement oven element, it may be the wrong one and could be tripping the breaker by drawing too much power.
Otherwise: Wiring or breaker not sized right, maybe another load on the breaker in addition to the oven, possible bad connections causing extra amperage, or wrong the oven element made for a higher amperage oven. In rare cases the breaker might be bad, but this is not likely.
Someone experienced needs to a) identify the breaker size b) verify the wire connected is appropriated sized c) verify the oven's current requirements and d) look for bad connections.
Normally another load would not be on the oven circuit unless a diy person changed the wiring. With those items verified, a clamp on amp meter would be used to verify actual current draw when the oven is on to ensure the load is appropriate for the breaker, wiring and oven. If at this point the load is less than 80% and the breaker still trips, change the breaker.
May 25, 2014 | Ovens
Neff u1421 double oven , both ovens work fine but the grill trips the circuit breaker after 5 minutes of getting hot
you need to check size of breaker the oven is wired too if this is to small it will trip also cable size
Sep 18, 2013 | Neff U1421 Double circotherm Electric Oven
What size breaker and wire for this oven
Hello Sbilko,
I understand that you are tring to find a breaker and wire size for your GE JKP28 Double Oven. As I look up the specs on your oven I find that both ovens are rated at 30 amps. This requires you to use two thirty amp breakers one for each oven. The industry standard for Oklahoma requires that you use at least #10/2 wire for a 30 amp breaker. However, in some places it states that you can use #12/2 although I would not recommend using #12 gauge wire.
My suggestion to you is two 30 amp breakers and #10/2 gauge wire, this should be what will take care of the circuits and keep the wire form heating up.
Thank you for choosing FixYa.com
Justin
Mar 29, 2011 | GE JKP28 Electric Double Oven
We just purchased a Kenmore Elite double oven (model # C970-600131); we don't like the intensity of the neon clock light; too bright to read the time from the next room; is it possible to turn this...
no it is pre-set and not adjustable.
perhaps some auto-tint over the display will help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | Kenmore 43389 Electric Double Oven
1981 oven..switch not operating/ needs a top door..cannot find parts.
Appliance Parts Pros of ohio,if they dont have it they will find it for you and prices and shipping are reasonable and fast
Jul 24, 2009 | Kenmore 43389 Electric Double Oven
Top oven door will not unlock
turn off the breaker to the oven for an hour and then back on that should do it
Jul 15, 2009 | Kenmore 43389 Electric Double Oven
I have vulcan Double stack electric ovens 208v 3ph.what size breaker do I need to power each oven
I need to know the Power rating Example 5Kw or the Ampere Ex. 30A . What is the raring of each oven? The Breaker should be greater than the Ampere of your oven let say 120% greater.
Jun 11, 2009 | Vulcan Convection Oven - VC44EC-208-3
Breaker sizw
In most cases look on the model number tag, the one with the serial number on it and in most cases it will tell you what amperage breaker you should run it off of. It could be a 30 amp 40 amp or 50 amp 220 breaker.
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Heating problem
standard range 40 amp breaker
Apr 05, 2008 | Whirlpool RBS245PDS Electric Single Oven
Kenmore 43389 Electric Double Oven Logo
57 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
