Question about GE Dryers
How do you remove the drum on a GE DSXH43EV1WW electric Dryer? I have the top off, the rear access panel off and the belt undone.
the dr
  • 447 Answers
SOURCE: belt replacement
I Can help ..... Remove 2 phillips screws under lint filter pull top of dryer forward and then raise like hood of a car Remove 2 5/16 Hex screws holding front on dryer Disconnect door Switch let front hinge down a tiny bit and up and off Belt is routed with idler hinged into base of the dryer 2 slots
Posted on Oct 05, 2007
  • 1073 Answers
SOURCE: Replace belt on Whirlpool LE09508KQ1 Electricl Dryer
remove the lint fiter and remove the two phillips screws then lift the top up
you will find two screws on each side of the inside of the frount panel down about 4 inches , this when removed will allow you to swing the frount arround to gain access to the belt
Posted on Apr 30, 2008
IFIXALL
  • 868 Answers
SOURCE: GE,Dryer,dbxr463ed1ww,
It sounds like the belt broke off. Unless you have replaced even just the belt before,you need a experienced repairman, trust me.....
Posted on Jun 03, 2008
captaynkyrk
  • 170 Answers
SOURCE: ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. http://www.partselect.com/MultiModels.aspx?ModelNum=dde7100&searchTerm=&RefineSearch=0. This can help you figure out what parts you might need and how things go back together. Good luck!
Posted on Jul 14, 2008
SOURCE: replacing belt on candy cdc266 reverse action dryer
i have i candy cdc 266 reverse action tumble dryer and the condenser has gone on it
Posted on Oct 07, 2008
How do you take off the back panel to get to the inside?
you cant remove the rear panel the sides and back are all one piece,you remove the control panel screws in the back,then the control panel,then the top panel cover comes off,the front then comes off,remove the drum belt and drum and you can get to the inside rear wall from here
Jul 17, 2011 | GE Profile Harmony DPGT750EC Electric...
GE Dryer MOD: BBXR463ED2WW SER: ZH775302A Dryer is getting louder when in use it creams when in use. think it might need a belt? other problem: When I turn the controll settings it goes on without turning...
The roller for the belt tensioner has a bad bearing. replace that item as well as the belt
The start button is stuck to the start position so replace that as well
The top & front panel will need to come off to repair both items
May 23, 2010 | GE DBXR463EDWW Electric Dryer
GE electric dryer (model #: DRSR483ED2WW) sounds like grinding metal when dryer starts/runs
you need to replace the rear drum bearing by removing the front panel lower screws and then remove the top cover and lean back and secure so as not to break wires to control panel,then remove drum belt,lift out drum and replace with bearing kit
Feb 01, 2010 | Dryers
Replacement of belt on dryer
Here's how to replace a belt on an GE Profile DPSE810EG4 electric dryer. There may be some minor variation for other electric GE dryers, but it shouldn't be too different. DO NOT USE THESE INSTRUCTIONS ON GAS DRYERS AS ADDITIONAL PRECAUTIONS MAY BE REQUIRED! For the electric DPSE810EG4, you will need a #2 Philips screwdriver, a flashlight, a new belt, and patience. You will also need something very close to the left front of the dryer against which you will lean the front panel. A chair, a washing machine, or a wall all work fine for this purpose.
1) UNPLUG THE DRYER FOR YOUR SAFETY.
2) Pull the dryer away from the wall and disconnect the ducting.
3) Remove the top four screws on the back panel. (These secure the control panel)
4) Open the dryer door and remove the two screws on the top of the door frame. (These secure the top panel.)
5) Pop up the front of the top panel and slide the top panel forward an inch.
6) Unlock control panel by sliding it to the right, then pull it up to detach it from the top panel.
7) Lift off the top panel and set it somewhere
8) Undo the two screws that hold the front panel.
9) Pull up a little on the front lip of the drum while hinging the front panel forwards. On the DPSE810EG4, you can set the drum down on the support member that is underneath it. (On other models you might need to put something under the drum for it to rest on.)
10) Lift the front panel off of the pins that secure its lower end, and then hinge it to the left (be careful not to yank the wires). Lean it up against something.
11) Open the access door on the back. (On the DPSE810EG4 the access door is the exaust duct itself; remove the screw that secures it and slide it out of the dryer.) Set your flashlight inside the dryer aimed so that you can see the motor and the tension pully.
12) Remove the old belt. If it's snapped in half you can just pull it out. Otherwise, reach in through the back access door with your left arm and pull it off the motor, then come around front, lift up the front of the drum a little and slide the belt off the drum.
13) Reach in through the back access door with a cloth and remove any grease blobs on back of the tension pulley axle. (This way you won't accidentally get grease on the belt during the difficult step which comes next!)
13) Install the new belt. Lift up the front of the drum a little and slide the new belt onto it (the side with the parallel grooves should be touching the drum). Reach into the back access door with your left arm. Grab the belt and pull it around the right side of the plastic tension pulley and then pull it down around the metal motor pulley. You're less likely to get your fingers stuck if you grasp the belt from the front. (The side of the belt without the parallel groves should be in contact with the tension pulley. The side of the belt with the parallel grooves should be in contact with the motor pulley.)
14) Replace the front panel. Set it down on the pins, then hinge it forward while pulling up on the front lip of the drum. Secure the two screws.
15) Make sure the drum turns OK. (If it's fairly difficult to turn, you may wish to try removing the front panel and then try putting it back so that the drum sits inside the felt strip semicircle rather than compressing it. A drum that doesn't turn well will stress the motor and cause it to pause mid-cycle.)
16) Replace the top panel. Put it on top of the dryer, insert the control panel tabs into it, and lock them by sliding the control panel to the left. Slide the top panel back and pop it down in the front. Secure the front with the two long screws and secure the control panel with the four short screws.
17) Replace the rear access door / exhaust duct. Double check that you didn't leave anything inside (including your flashlight). Slide the exhaust duct back into the dryer and secure the screw that holds it.
18) Re-attach the rest of the ducting and move the dryer back into position.
19) Plug it in and make sure it works.
Dec 21, 2009 | GE Profile Harmony DPGT750EC Electric...
GE DRYER HEATING ELEMENT
Yes, the whole drum needs to be removed:
Before you go trough this make sure you know for sure your elements need replacement by checking for continuity at both element terminals.
Make sure you do the same with your high limit thermostat on housing.
How to remove the drum?:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Aug 17, 2009 | GE DSXH43EF Electric Dryer
Drum not turning. Where is belt? Kenmore 110
The belt is on the outside of the drum and is accessible from the rear of the dryer. If you remove the access panel on the bottom rear of the dryer, you will see the motor, where the belt is on the motor sheave (pulley). On some Sears Kenmore models you need to remove the top cover of the dryer to access the belt around the drum (towards the rear).
Aug 02, 2009 | Dryers
How do you disassemble a GE harmony dryer
remove rear pannel and the motor is right there remove drum to acess the motor
remember to lay the dryer on an angle or even flat on it's face if you can to re insert the drum assembly and dont forget the belt
Jul 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Heating element
1. pop the top
2. remove the front
3. remove rear access panel, get belt off motor
4. remove drum retainer(where applicable)
5. grab belt at top of drum, using belt as handle, yank it straight up off the rear bearing mount( do not remove the screws inside the drum)
Jan 31, 2009 | Frigidaire GLER642A Electric Dryer
Blower motor access
You cant you have to remove the control panel, dryer top, top heat shield, dryer front, front drum support, belt, and then the drum in that order to get to the heater. I have been working on these since they have been out and have never changed a heater in one, They just dont burn out. Unplug the dryer and take the access cover off where the power cord attaches to the dryer and make sure the wires are not loose or burnt.
Jun 01, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Electric dryer blower issue - how do I access?
You have to remove the control panel, dryer top, top heat shield, dryer front, front drum support, belt, and then the drum in that order to get to the heater. I have been working on these since they have been out and have never changed a heater in one, They just dont burn out. Unplug the dryer and take the access cover off where the power cord attaches to the dryer and make sure the wires are not loose or burnt.
Apr 21, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
171 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
