Question about Dewalt 3800 PSI Pressure Washer
SOURCE: My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
Good luck
Regards
PCmania
Posted on Jul 05, 2009
SOURCE: cannot get it to uptake the bleach for spraying
On most pressure washers you wont be able to draw soap/bleach into pump unless you are spraying on low pressure.There is a valve on the inside of inlet hose fitting that closes when high back pressure is sensed.Would it draw bleach into hose when wand tip is removed?
Posted on Nov 21, 2009
SOURCE: Dewalt 3800 PSI operates great
When you pull to start squeeze the water hose tigger until start.
Posted on Oct 03, 2010
SOURCE: Hi, I have a Dewalt pressure
There are two common issues that will cause what you are describing. What you need to do is run the machine until it dies as you are describing. Then pull the spark plug and check for spark. If you do not have spark you have a failing stater. It is very common for this problem to only show itself after the machine warms up. If you find that you do still have spark try removing the gas cap and restarting. It is also common for a vacuum lock to occur due to the seal on the gas tank cap. In most cases one of these will be your issue. If not feel free to contact me at 800.247.8103 and I will help you to troubleshoot the issue further.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Posted on Mar 10, 2011
SOURCE: Hi, My Dewalt 3100 pressure
The Dewalt 3100 came with 2 different pumps. The Blue Cat pump and the oil free pump that was made by DeWalt.
You may just have a bad Thermal relief Valve on the unit.
You can find the parts diagram at www.allpartsinc.com
Posted on Oct 01, 2011
Jun 09, 2016 | Craftsman Professional 3100 PSI,2.8 GPM...
Jul 22, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Sep 26, 2013 | Homelite Pressure Washer. 3,100 psi 2.5...
Feb 01, 2018 | Dewalt Pressure Washer. 4200 PSI 4.0 GPM...
Sep 08, 2011 | Dewalt DPH3100 Gas Pressure Washer
Mar 08, 2011 | Dewalt DPH3100 Gas Pressure Washer
Oct 03, 2010 | Dewalt 3800 PSI Pressure Washer
Aug 11, 2010 | Dewalt 3800 PSI Pressure Washer
Nov 21, 2009 | Dewalt Garden
198 people viewed this question
