Question about HP Office Equipment & Supplies
On my lj1300n I get an error code of 10.758. Can
On my lj1300n I get an error code of 10.758. Can u help?
    Sergeant:
    Novelist:
  • 183 Answers
Hello there afrantz.
Here's your geek-steer ...
Is error code persistent? What other than the code is the problem (won't print, etc.)?
Try a basic device Reset/Reinitialize:
  1. Shut down the computer system the printer is connected to.
  2. Unplug the printer power cord from both the printer and its power outlet.
  3. Wait at least 5-10 minutes, then re-plug both ends back in.
  4. Switch on the power button to the printer.
  5. Restart (reboot) system.
Here is the HP support web-page for your device.
Are you receiving indicator light error sequences? If so, refer here.
Are you receiving an error message in list form such as is displayed by this (only other forum input) user with identical error code? And like him, does your user manual NOT include an error code index? I would presume not, because it's not located at HP support websites, or via a thorough web search, which yields nothing readily found elsewhere. Therefore I can only conclude, as is all-too-often the case, the manufacturer (HP) maintains that info in a proprietary status, and thus only available in their "service" manual publications.
You might try contacting HP support (email/phone) specifically querying your error code's definition and suspected problem/resoluion ... whether it's under warranty or not.
Good luck, and please do post back to ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback.
  • if you have any further questions,
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Posted on Oct 06, 2009
  • Craig The Geekinator
    Craig The Geekinator Oct 06, 2009
    @ afrantz
    Just looked at that error "list" of that other user. I now see that it is an "Event" log error report. It's all but a certainty that's from Windows. Apparently this error you share with him declares to the Windows Event Log. You may want to see if you are receiving same from yours.
    Start > Run ... > type "compmgmt.msc" (without quotes), then OK ...
    Computer Management > System Tools > Event Viewer > ...
    Then check both the "System" and "Application" logs (also for any HP specific log if it exists) for relative entries matched by time the error occurs, by double clicking any line in list on right column, then using the up/down arrow icons.
My DAEWOO washing machine shows E9 error . How can I fix it.
Following is a summary of your problem:
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
You can check Daewoo Washing Machines' all Error Codes on the following link:
https://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/ Daewoo Washing Machine Error Fault Codes
Check the following link also:
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes
Feb 05, 2018 | Daewoo Washing Machines
How do i fix error code 42 on my cellphone? Help! Ive tried everything!
How to Repair Error Code 42 ' Windows Error Support - Error Tools
errortools.com/en/drivers/how-to-repair-error-code-42/
  1. Cached
  2. Similar
Code 42 Error is referred to as a Device Manager Error code. Before we explain what this code indicates, it is important to understand what 'Device Manager' is and its functions. Device Manager is basically a Windows tool that helps manage devices attached to the system such as the Printer, Scanner and the USB Device.
Error codes in Device Manager in Windows - Microsoft Support
https://support.microsoft.com/en-ca/help/.../error-codes-in-device-manager-in-windo...
  1. Cached
Lists the error codes that may be reported by Device Manager and the possible resolutions in Windows. ... Manager. If you are getting an error code that isn't listed here, you can contact the hardware device vendor's technical support or Microsoft Support for help. ..... Code 42 "Windows cannot load the device driver... (Code ...
ERROR CODE 42 - Boost Mobile Community
https://community.boost.com.au/t5/Setup-Phone-Support/ERROR-CODE-42/.../20989
  1. Cached
Sep 3, 2017 - 1 post Help! I can't send or receive text messages! It keeps saying: Error code 42 I can't call or receive calls either and I know that my bill isn't due.
Instructions To Fix Windows Error Code 42 - Error.info
https://www.error.info/windows/bus-driver-42.html
  1. Cached
  2. Similar
About the Error. The Windows error code 42 indicates the fact that the operating system has detected a duplicate device. This is usually caused by a sub-process that the system accidentally named incorrectly. Windows code 42 - Read what really helps. Though Windows error code can sound quite intimidating, fixing the ...
Dec 14, 2017 | Cell Phones
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What does error code f736333432b0f4610 mean?
    hat do the error codes mean?HostMySite
    www.hostmysite.com > Support > GENERAL SUPPORT
    Browser Error Codes. Linux and Windows ASP.NET, SQL, Coldfusion, and WebMatrix hosting backed by world class 24x7x365 toll free phone support.
    Microsoft Malware Protection Center - Error Codes
    https://www.microsoft.com/.../errorcodes.aspx
    Microsoft Corporation30+ items - Microsoft Security Essentials error codes. The table below has some common error codes from Microsoft Security Essentials. ... See I can't install Microsoft Security Essentials for more details. Error code
    Possible reason for error
    0x8004ff00
    Another Windows installer may be running
    0x80070643
    This is a generic error code - there could be an undiagnosed ...
    Netflix Error S7063-1417https://help.netflix.com/en/node/23463NetflixIf you experience the error code S7063-1417 on your Mac when trying to watch in Safari, use this article to resolve the issue.Why can't I connect to Netflix?https://help.netflix.com/en/node/461NetflixNetflix is Unavailable, Unable to Connect to Netflix, Android Error: Connection Failed ...These error messages are sometimes accompanied by an error code ...Netflix Error S7363-1266-00002E18https://help.netflix.com/en/node/22793NetflixIf you experience the error code S7363-1266-00002E18 while watching on your Mac computer, use this article to resolve the issue.
    Feb 03, 2016 | Netflix
    Fh error code wirpool duet washer
    Display shows F20 or FH - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...fh-front-load-...
    Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
    whirlpool duet error code FH - Appliance Repair Forum
    forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
    Jan 5, 2009 - 10 posts - ‎1 author
    ... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
    1 post
    Dec 5, 2014
    Whirlpool Duet Washer HF Error Code
    Jun 10, 2013
    FH Error Code on Whirlpool Duet Washer
    Mar 11, 2013
    FH error code
    Sep 13, 2008
    More results from forum.appliancepartspros.com
    Stumped on error code FH for Whirlpool Duet front load washer .
    Jan 08, 2016 | Washing Machines
    The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
    LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
    Select
    Use our model number finder
    Choose your product type
    Common model number plates
    Close
    LG Refrigerator Error Codes
    These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
    Er FS Error Code
    Er rS Error Code
    F dS Error Code
    r dS Error Code
    Er HS Error Code
    Er IS Error Code
    Er SS Error Code
    Er rt Error Code
    Er It Error Code
    Er gF Error Code Error Code
    r dH Error Code
    Er IF Error Code
    Er FF Error Code
    Er CF Condition
    Condenser fan motor is defective Check/Repair
    Condenser fan motor, wiring or the control board Shop Parts
    Condenser fan motor, Power control board, Wiring harness Error Code
    Er CO Condition
    Communication error Check/Repair
    Communication error between main board and display board Shop Parts
    Display control board, Power control board, Wiring harness
    Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
    How to fix canon mp258 error code 2,140,2 when i scan douument
    please help me....
    I m trying to scan my document but it is showing error code 2,140,2 on PC and error code E5 at printer....my catridiges is empty is it because of that reason............
    Aug 11, 2012 | Canon PIXMA Office Equipment & Supplies
    Error code from my xbox 360
    http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
    Jan 18, 2009 | Microsoft Xbox 360 Console
    109 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
