Question about Belkin (F5D7011) 802.11g/b Wireless Adapter
I got belkin wireless g gaming adapter for my xbox 360 the other day and i downloadaded the cd on my computer and followed the instructions, but when i put it in my xbox 360 the xbox couldnot find the adapter and i have tried the ip address but nothing happend
  • 2,260 Answers
You will need to match the wireless settings of your router and the gaming adapter.
Who is the manufacturer of your router?
connect your computer to the router with the cable and open the set up page of the router. check the wireless settings of the router SSID, Channel, security settings.
now you gaming adapter and the Router IP address should be in the same range. Suppose if the router IP address is 192.168.x.y and the default IP address of the gaming adapter is 192.168.a.b., then the number x should be equal to a. If it is not then you will need to change the IP address of the gaming adapter so that x will be equal to a.
after that open the set up page of the gaming adapter and change the wireless settings.
power cycle the router and the gaming adapter and now it should work.
For more info about networking Click Here
Posted on Oct 07, 2009
  • Prashant M
    Prashant M Dec 05, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
Connecting a tp link wireless usb adapter to xbox 360
It is not possible to use generic usb wireless adapters with the Xbox or Xbox 360 game console. By 8246b47.jpgJohn Anderson Jun 20, 2012
The post John Anderson is correct that this would not work with a XBOX device. These are intended for and installed on computers (laptop or desktop) with which you would need to install drivers for it on. There is supported drivers that will allow the installation of this device into either a XBOX or PlayStation gaming console.
Best Regards!TP-LINK Support Teamhttp://www.tp-link.com/us/supporthttp://www.facebook.com/TPLINK
Jun 20, 2012 | TP-LINK TL-WN727N , 150Mbps Wireless Lite...
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
How do I connect my xbox 360 to the wireless internet?
For the Xbox 360 Slim, on the dashboard console:
1) Go to Settings
2) Select "System" to take you to the system settings menu
3) Highlight Network Settings and select it
4) Select Wireless Network to setup your wireless
For older Xbox 360 consoles:
1) Your will need an Xbox 360 Wireless Networking Adapter. Check online or your local stores to see if there is one available.
2) Once you have the adapter, simply hook it up to your xbox and follow the instructions at the top of this solution to setup your wireless through the xbox dashboard.
Feb 23, 2012 | EA - Electronic Arts Video Game Consoles &...
I have xbox 360. i have a computer with a wireless router. what do i need to connect the xbox to the computer,wirelessly
You'll need to buy an xbox 360 wireless adapter such as this one: http://www.amazon.com/Xbox-360-Wireless-Network-Adapter-Networks/dp/B000B6MLV4
Mar 25, 2011 | Microsoft Xbox 360 Console
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
I just bought a Belkin wireless router for my internet to connect with my microsoft xbox 360 wireless adapter. the light turns on the adapter but it is a amber color and not red or green like always...
I've never heard of a Wireless Adapter turning amber or orange? This can be a simple light problem inside your Xbox 360. If it were fixed, the highest possibility is that color should be red. If so, this means the connection is not strong enough to your modem, and adapter. You will have move your Xbox 360 console closer to your wireless modem for the connection to be the best.
Dec 31, 2010 | Microsoft Xbox 360 Console
My wireless adapter light is green, yet i cant connect to xbox live!
first check whether the gaming ports for xbox have been forwarded in the belkin router or not....if not do it first....if you dont know the port numbers call xbox support and get the list of port numbers to be forwarded....
then enable DMZ for the ip address of XBOX in belkin router...
then enable UPNP in belkin router....
atlast Disable firewall in belkin router.... your XBOX will go online and GET UPDATE..... you can call belkin tech support of your country to assist you to forward ports for XBOX in belkin router... if you reside in USA/Newzealand/Australia/Canada you can call this toll free 1800 2 BELKIN(235546)...... or you can call my personal mobile... Im from India country code +91 Mobile number 9003593572
Apr 08, 2010 | Microsoft Wireless Network Adapter Xbox...
I have a wireless network at home what do I need
You will need an Xbox 360 wireless adapter. It is not an accessory that usually comes with an Xbox 360. After that you just need to follow the instructions that come with the accessory and set up your internet settings in your console's setting section.
Jan 18, 2010 | Microsoft Xbox 360 Elite Console - Black
How to conect belkin wireless g usb net adapter to xbox 360
You can not use the Belkin Wireless G USB Adapter for the XBox 360. You must buy a USB Wifi adapter that supports the Xbox 360. (See Microsoft's USB WiFi Network Adapter)
Nov 16, 2008 | Belkin (F5D7000) 802.11g/b Wireless...
Belkin (F5D7011) 802.11g/b Wireless Adapter Logo
839 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
