Question about Toshiba TDP-SP1 DLP Projector
Source: pc no signal
I only get pc no signal. I has worked in the past by just rebooting computer but that isn't working any more
  • 4,281 Answers
Open cpu cabinet.
Then refix RAM memory.
Pull processor fan and then processor remove dust from all parts and circuit.
Reattach both processor and its fan.
then check if still face same issue.
Then pull cmos cell from motherbord.
Change RAM memory slot module .
Remove pic cards from PCI slot.
Reattch ATX power connector from smps to motherbord.
Then check.
If still face same problem then your RAM has need to be replaced.
Let me know if you need more assistanse.
Posted on Oct 06, 2009
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
Acer Veriton 6900 Desktop says no signal and the screen turns off. The towers power light stays on but the fan isn't running.
Change the power supply and restart your pc. This will happen when the power supply has gone bad. It sends power to low voltage items but not the needed voltage to power the system on.
Good Luck
C2Solutions
Feb 14, 2012 | Acer Veriton 6900 PC Desktop
Password problem
Hi there.
In the windows 98, start menu, and then find your way to setings, control panel. And from there passwords. Since its been a long time Since I last used a windows 98 pc I had to google the solution, here it is, copy pasted from computer hope (http://www.computerhope.com/issues/ch000131.htm#02)
  1. Open Control Panel
  2. Open the Passwords icon.
  3. Click the User Profiles tab
  4. Select the first option "All users of this PC use the same preferences and desktop settings."
  5. Reboot computer.
  6. After the computer boots up and no password was entered, reboot again to see if the changes fixed the computer.
My memory isn't so good that I would remember the things from 10 years ago exacly.
Oct 21, 2011 | Microsoft Windows 98 for PC
I need the maual for this rca tv L37wd22yx6 tv just keeps saying unusable signal and i need the maual
What is the signal source for the TV? Make sure that you are on the correct input. Use the Input button on the remote. If you do not have the original remote, you need one that matches that function. (Often a Source or Input button is not available on the low end remotes.) Check that you have the signal set to Antenna or Cable if you are using the coaxial connection and the source is TV. (Menu > Setup > Channel Setup > Signal Type)
If your source is a computer, use the VGA port not the HDMI port. Computers send a different type of video signal than video set top boxes. The L37WD22 can't interpret the PC signal on the HDMI input.
For a set top box on the HDMI port, the unusable signal message indicates a communication issue. Try pressing the Info button on the remote. If you see an additional message of Acquiring Channel, then the set top box isn't responding to the remote. Check that the device is on and set up correctly to communicate with the TV. (For example, if your set top box offers progressive scan, try turning of that feature with the control for the box.)
The L37WD22 was built by TTE for the RCA label. The manual is available on the TTE support page.
The direct link to the User's Manual in English is http://support.ttetech.com/RCATV/Assets/pdfs/L37WD22_16788070_IB_e-07.pdf .
I hope this helps.
Aug 29, 2011 | RCA Televison & Video
No signal to monitor
Hi, Have u tried removing the RAM and CMOS battery and then again put it.
Jan 25, 2010 | eMachines T6534 PC Desktop
My monitor suddenly lost signal and hasn't returned
do you mean the processor fan that is located near on the left top corner on the motherboard? if that stopped working then turn of your pc immediately. probably the cpu overheated. if that fan does not work replace it immediately as it will burn the cpu.
I keep getting a no pc signal even though I'm connected.
if you get no power, you'll need to replace the power supply. if you are just not getting a signal, reset the settings to factory default on the projector and replace the cable.
Oct 06, 2009 | Toshiba TDP-SP1 DLP Projector
Serious error
Try opening your computer and cleaning the fans around the CPU and the other fans in your system. Computers have a sensor that shut computers down when they get too hot. Clean all the dirt inside and you should see a little performance boost also.
Jan 05, 2009 | HP Brio BA PC Desktop
Recovery Manager
This may be a corrupt OS try removing the ram module (First remove all power sources including batteries) then clean the connection of the RAM modules using a pencil erraser replace them very carefully then reboot if this does not help buy a USB IDE connector converter you could basically open all your files in another computer to do this you need to remove your lap top hard drive buy the compatible USB IDE or SATA which ever fits you hard drive then connect it to a PC like using a USB Flash disk or Card
May 31, 2008 | Acer Aspire 5100 Notebook
Toshiba TDP-SP1 DLP Projector Logo
51 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
