Question about SNK Cibox Inter@ctive C2201 22 inch LCD Monitor
A red line appears down the right hand side of my
A red line appears down the right hand side of my cibox monitor how do I remove it
  • sclem007
    sclem007 Oct 02, 2012
    my momitor displays for 5 secs and then a red light blinks
    Problem Solver:
  • 5 Answers
Dear friend . .
the line appears due to some tecnical fault of your monitor
if u have still in warranty period then just change it soon
Posted on Oct 06, 2009
LG20" monitor. Suddenly a red
Try to reset it
Scroll through the menu options by using the up and down arrow buttons located just under the "Menu" button. Scroll down to the "Setup" icon, which looks like a big cog. Press the "Auto/Set" button to access the Setup menu. Scroll, using the down arrow, to "Factory Reset." This setting is located at the bottom of the Setup menu. Press the "Menu" button on the right side of the monitor. This will bring up the On Screen Display. If nothing happens when the "Menu" button is pressed, press and hold it for several seconds to unlock the On Screen Display. Press the "Auto/Set" button to choose "Factory Reset" and then press the down arrow to reset the monitor.
Jul 23, 2011 | LG Computers & Internet
Screen cuts off image
To see the button on the right hand side of this monitor you will need to shine a really bright light on it, but the buttons from top to bottom are: 1, up-arrrow, down-arrow, and 2.
  1. On the side of the monitor press the 1 button to activate the menu.
  2. A configuration menu for the monitor will appear; from that menu highlight the "Input Select" menu item using the up and down buttons on the monitor; when you have the item high-lighted, press the 2 key.
  3. A new menu will appear, and then you can select the menu item called HDMI on the left and PC waaay over on the right. Select this menu item with the up and down arrows and when it is selected,
  4. And press 2 like you did in the previous step.
Apparently there's some sort of a strange difference between using this monitor as a "video monitor" and using it with a computer.
Nov 02, 2009 | ViewSonic VX2433WM 23.6" Monitor
Looks like a crack in the display
such issues have occured in the Past, Please Check if the Crack appears in the BIOS mode.Safemode also Try another Monitor to find out if it is not the wall paper because if it is then the Crack will appear in the other Displa too...
Jul 17, 2008 | Computers & Internet
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
If it's a straight line from top to bottom panel could be defective.Not much you can do as cost of panel will compare with a new monitor.
Samir
Jun 08, 2008 | Gateway FPD1975W 19" LCD Monitor
LP690 projector displaying strange lines
to adjust those mirrors, you need to power down, unplug, remove the top, remove the wires from the main board, remove the main board, adjust one mirror, reinstall everything, power up, see whatever difference it made, power down and repeat until it's fixed. it's quite a chore. if that's not the problem, you'll need to replace the optical engine (which isn't cheap) because they don't sell individual parts.
Mar 09, 2008 | InFocus LP690 Projector, Factory...
1inch black line down right hand of screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 15, 2008 | Computers & Internet
A single vertical red line
That means the LCD panel itself (the actual glass) is broken. Don't delay, return it and get another before it's too late! The problem will most likely NOT go away, and there is no fix other than to replace the panel itself. The panel, when purchased separately, can cost more than the monitor itself.
Dec 27, 2007 | LG L1915S 19" LCD Monitor
Red Line
I was just looking at Samsung's site regarding this issue. It is most likely a line of dead pixels. Direct from their site: "The thin red, green, blue, white, black, or yellow line you see running through your LCD monitor is most likely a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced. To set up a service appointment, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your monitor's model number and serial number on hand when you call." http://erms.samsungusa.com/customer/sea/jsp/faqs/faqs_view.jsp?PG_ID=1&AT_ID=15336&PROD_SUB_ID=28&PROD_ID=-1
Jun 21, 2007 | Samsung SyncMaster 213 T 21.3" LCD Monitor
SNK Cibox Inter@ctive C2201  22 inch LCD Monitor Logo
212 people viewed this question
Top SNK Computers & Internet Experts
David Payne
David Payne
Are you a SNK Computer and Internet Expert? Answer questions, earn points and help others
