Question about Hoover F5826-900 SteamVac Upright Wet Washer
We are getting no suction with the machine. It
We are getting no suction with the machine. It doesn't draw the water back up.
    Scholar:
  • 190 Answers
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Posted on Oct 07, 2009
I have the bissell pro heat turbo microban cleaner. It's about 2 1/2 years old and maybe used 8 times. The brushes do not work and it's not suctioning up the water. I've checked the belt on...
You already said it, so check the carbon brushes. Once it is no longer able to push the rotor or stator it need to be replace. Carbon brushes are customized at the machine shop, so you should bring it so that you have a sample of the brushes itself. Just be observant when disassembling the motor so that you put it back to exact place.
Thanks for asking.
Jul 13, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have assembled the shampooer, but the water and shampoo is not being drawn up into the tubing, what did i do wrong??? sally
When you coupled the unit the system might not have been tight that's why the unit is refusing to draw up the water and the shampoo. The unit is meant to be airtight and when the unit is not airtight then the power to draw up the shampoo and water will not be sufficient. Try to get the system tightened and it should be able to draw up the water and shampoo.
Hope this solution has been helpful?
Jun 29, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Suction problem
Possible Problem #1: The dirt water tank lid may be the reason the machine is not sucking up the water. There is actually a gasket on the bottom of the lid where it connects to the actual tank itself. If the lid is not put back on properly (this is really easy to do, I've done this myself many times on my Hoover SteamVac), and the gasket is not sealing the lid to the tank, this will allow the suction to leak, greatly diminishing the suction power to **** the water back up. Try removing the lid and reinstalling it, making sure that it's put back on the correct way, and try to see if this fixed your problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture, and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Possible Problem # 3. If neither of the first two possible problems were the source of your suction loss, try this one. Turn the machine upside down (you should probably remove both the clean water tank and dirty water tank before doing this, just to ensure that no water spills when you turn the machine over) so that the brushes are facing upwards. Look right behind the brushes for two red plastic tabs that are slightly sunken into the bottom housing of the machine. Pull these two tabs upward as far as they will go. There is a metal filter screen that will be exposed when you pull the tabs. Make sure that this screen is clear of debris. This screen protects anything from going into the motor, and if it has debris blocking it, this can cause the machine to loose suction.
Also make sure that there is nothing in the clear plastic suction channel on the top of the machine where you can see the water being sucked up. Sometimes if something gets stuck in this suction chamber, this can also cause the machine to loose suction.
Also it may be that your motor is dying, and loosing suction power. Usually if this were the case the motor would continually get louder and louder, until it just stopped working. To test this, put the machine in the upright position, and remove the dirty water solution tank. If you look at where the dirty water tank rests, you should see a circular tube underneath of where the dirty water tank sits. Here's a picture that I took, that has this part circled: Put your finger down into this suction port and see if you can feel any suction coming through when the machine is running. If there is suction, then your problem is definitely going to be one of the above problems, and if there is no suction, this indicates a more serious problem with your motor. If you don't feel suction here, you may want to consider taking the machine into a repair place, or even consider to possibly getting a new machine at this point.
I really hope that this helped you find the cause of your suction loss. If you were able to diagnosis this problem, and would like me to help you fix the cause of the suction loss, I'd be more then happy to now walk you through the repair as well. Please just use the Clarification Request form here on the same page, and I will then help you out with your repair. I just ask that if this repair was helpful to you, please help other Fixya members to find it, and rate the repair helpful by clicking the 4 Thumbs Up icons in the top corner of the repair.
Thanks,
Chris Jones
GoVacuum.com
May 11, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My steam vac stopped sucking up the water. How do
Hi There,
Here's a link to the instruction manual for your Hoover SteamVac. There is a trouble shooting guide in the back of the book that will explain how to check no suction problem.
If none of these suggestions fixes your machine, please just refer to my answer below the link, these are the problems you may have.
Here's the link:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
There could be several problems that would cause the dirty water tank to be empty after you've cleaned the carpets. I'll try and walk you through each to help you diagnosis the problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture2_bing.gif and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Thanks,
Chris Jones
GoVacuum.com
Apr 23, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Why is the "dirty water" reservoir still empty after I cleaned the carpet?
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Thank you very much,
Chris J.
GoVacuum
Apr 09, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
No water spraying, suction still working
I have a Bissell as well, and found that your issue sounds like there is a blockage in the hosing to the main cleaner part of your machine, The siphon action of the suction that your machine is obviously working in that you state that your accessories tubing is working. There is a split though in your unit. probably under the hood of the machine which splits the pressure between the accessories and the main unit. I highly suggest you look there to seek your blockage.
This unit works like a "straw" in a soda pop.. the unit makes a suction draw and that draw is directed to the main unit area and the accessory area, splitting from the main suction line..
Another suggestion though might be to be sure your accessory line is not "open" when you are trying to use your main unit.. you can test this by seeing it it squirts when you run your main unti as well.
Summary then is to check that there is no blockage after the "T" where the pressure seperates to the main squirter and the accessories.. This should be fairly obvious to see and a little cleaning should resolve this right up for you.
Hope that helps!
Stan
Sep 19, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Dirtlifter Powerbrush carpet cleaner will not roll. The back wheels roll fine, but when you put the machine down flat, the front part (where the roller is) sticks and will not roll.
I had the same problem. It would pull backwards but not go forward. A closer examination revealed the clear plastic part on the bottom in the very front of the machine had popped loose on one side.
If you look at the front of the machine, there is the clear plastic part on top where you see the dirty water being sucked up. The bottom half that creates the channel for the vacuum is where it came loose. It wouldn't create enough suction to draw the water up either. By taking out the two screws that hold the top part in place and removing it, I was able to snap the bottom back in. Works fine now. Hope this helps.
Apr 14, 2009 | Vacuums
Not sucking up dirty water
Sounds like the suction motor is not working correctly. Either clogged with dirt or objects or it is failing.
Check this first:
Not suctioning properly, first check the motor duct gasket. To check this, first remove the tank and place your hand over the rubber square opening.
If your machine does have suction at the duct, continue to check the following:
Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE
ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced.
Check the Tank Lid and Tank for damage.
If there is no suction there, please take your machine to a BISSELL Authorized Service Center for inspection.
Jul 31, 2008 | Bissell 1699 ProHeat Clear View Upright...
Floormate not suctioning water back up
I love my floormate so muck that when my first one stopped vacuuming, I bought a new one - just figured it died. Then my new one worked well until one day, it suddenly stopped.
I discovered that the filter attachment holder (the clear plastic cover over the filter) has to click into place. I guess this might not be a problem for some, but I thought it just sat there over the filter. I finally pushed pretty hard (mostly in frustration at first) and it clicked into place. Now the suction works fine.
FWIW
Jul 11, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Won't extract water from carpet.
Seems the 1950W is now obsolete, cna't even bring up a drawing of it. Usually when the vac. motor is running, then there has to be suction. But if a seal or gaske is missing, then the suction will be lost. So you might check the dirty water tank to make sure there isn't a part missing or out of place. Check this out, it is for a 1950-3:
http://bissell.com/images/schematics/1950.pdf
Jan 29, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Hoover F5826-900 SteamVac Upright Wet Washer Logo
166 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
